I have several VIDEO_TS files that I have been trying to burn as DVDs but I get a message that they are encrypted with CSS. I have never run into this before this past week. I am using Toast 7.0.1. Is there another way to burn the files? All of my searches here haven't helped.
Thanks.
Sounds like the VIDEO_TS -folders- (not files, right?) were Finder-copied rather than "ripped" using something like MacTheRipper or 0seX; hence, the encryption was never removed. Not sure if it's too late to rectify this. Others will surely chime in on this soon.
You can remove CSS from a VIDEO_TS folder on a HDD using YadeX.
or try dropping the VIDEO_TS folder into Toast,
on the DVD From VIDEO_TS folder tab,
and then go File-->Save as Disc Image.
Then, after the disc image is made, re-mount using
Toast. Then rip the disc image with Mac The Ripper,
to a diffrenet location. Once done, trash the original."Everyone has to learn, so that they can one day teach."
When I'm not here, Where can I be found?
Urban Mac User -
I think YadeX ceased development at version 0.99. Any of the versions will remove CSS if that is truly whats going on with your folder.
HDD = hard disk drive ... as opposed to HD, which is high definition. -
You could always use MacTheRipper to remove CSS (this is what I regularly use, never had any problems! Just make sure to play the DVD in Apple DVD Player. I don't know why exactly, but if I haven't then sometimes it gives an error when ripping)
VIDEO_TS Folder CSS Encrypted
By utseay3 in forum MacReplies: 6Last Post: 8th Dec 2013, 21:57 -
Best encryption algorithm?
By alegator in forum ComputerReplies: 5Last Post: 10th May 2009, 23:37 -
removing CSS from a video_ts folder?
By ehmjay in forum MacReplies: 23Last Post: 29th Feb 2008, 20:15 -
How to detect a VIDEO_TS folder is pre-flagged with CSS
By newcyberianDVD in forum Authoring (DVD)Replies: 0Last Post: 28th Feb 2008, 15:54 -
Convert a CSS Encrypted PAL VIDEO_TS folder to NTSC DVD with subtitles
By Lord Stinkfoot in forum MacReplies: 6Last Post: 25th Oct 2007, 18:35
