Hi...I'm currently using a Daewoo Multiformat DVD Recorder with good specs which works perfectly.
However, Maxell DVD+RW's with disc unfinalised : if for example, I have three thumbnails (say, A, B, C) of recorded material and want to keep A, but delete B & C, then all I get after deletion are: empty thumbnails for B & C up to the recorded time previously used for each.
In other words, the empty space is not shuffled up...
This means I can only 're-record' material that would fit into these time-slots...not an ideal situation...
Trying to erase an 'Empty' thumbnail cannot be done on the Daewoo. So, I cannot 'release' the empty space in that way.
Also, if I wanted to erase 'A' as well, I'd then be left with THREE slots that could only be used as above...
In other words, I couldn't erase the whole disc and free up the full space again...Exactly the reason for having RW discs!
I've tried deliberately recording over the time limit, but the recording merely stops at the time available for that slot...
I have also used Imation DVD-RW's as above with no problems - the deleted thumbnails in this instance are 'gathered' up so as to present ONE empty thumbnail - ie the capacity of A+C. Perfect!
Now: does anyone know if this is a 'problem' with all '+RW's'/ just Maxell's?
Or has anyone experienced this with Daewoo recorders in particular?
Regards
Results 1 to 1 of 1
DVD Shuffling Required
By JamieLee2k in forum Authoring (DVD)Replies: 1Last Post: 15th Apr 2012, 10:50 -
Empty CD/DVD Spindles???
By rmbean in forum MediaReplies: 5Last Post: 9th Aug 2011, 13:26 -
Empty DVD?
By Han Solo1 in forum Newbie / General discussionsReplies: 28Last Post: 12th Nov 2009, 01:59 -
There is clicking and shuffling sound in my audio
By shashgo in forum AudioReplies: 11Last Post: 9th Dec 2008, 20:05 -
Is VCD/DVD disc space limited by time, or space?
By pingosimon in forum MacReplies: 6Last Post: 14th Jul 2007, 20:55
