Hi,
I was wondering why tmpgenc for SVCD has a QC level of 65? Do they just pick a level? Or is 65 some optimum level or fair size/quality trade off? I'd rather have it at SVCD specs.
The quality level has no effect on whether your svcd complies to the Svcd specifications, thats handled by your max bitrate setting.
There have been numerous tests done on how TMPGenc's CQ mode distributes bitrate. The general consenus is that with anything over %60-65 the quality doesnt increase that much while the filesize gets dramatically larger. So yes you are correct, a quality level of ~65 is probably the best balance between quality and compression but no matter what your settings you will never achieve as good a quality per size as multipass vbr. -
yep..like wut adam said.
for example, if you're using CQ_VBR and set max bitrate of 2100. if you set your CQ to 100, then it is basically the same thing as if you use CBR with a bitrate of 2100.
basically, the closer you set the CQ to 100, the closer to the max bitrate your dvd rips will be. as adam said, anything much higher than 65 for CQ is waste because the filesize gets bigger but little increase in quality.
constant buzz from earphones
By ecos in forum Newbie / General discussionsReplies: 4Last Post: 4th Feb 2012, 18:43 -
Editing volume levels without too much video quality loss.
By meneedit in forum EditingReplies: 7Last Post: 30th Sep 2010, 05:29 -
Constant resolution in GK
By eliqush in forum EditingReplies: 0Last Post: 5th Aug 2009, 10:28 -
I need a constant bitrate
By alexv305 in forum Newbie / General discussionsReplies: 6Last Post: 6th May 2008, 06:38 -
Staxrip: "Constant Quality" vs. "Exact File Size"
By FallenAngelII in forum Video ConversionReplies: 1Last Post: 9th Aug 2007, 17:40
