Well I`m using the Apollo DVD Creator, everything goes fine, until I play the DVD , or the VOB files, there`s a synchronizing problem between video and audio, the video seems to be a little bit ahead of the audio, in example, if someone hit a drum, the sound appears like 0.3 seconds behind, is that a program problem, or some codec is missing perhaps?
What is your source ?
How did you convert it ?
I don't know this software, but if it converts the source and authors it, it is probably the culprit. If the source is downloaded avi files then there is a good chance they have VBR MP3 audio, which many converters do not handle very well.Read my blog here.
All the files are MPEG downloaded from VideoPimp, UrbanChaosVids and others.
The steps are :
-Open Program, of course lol.
-Then I add the files
-Design the menu and buttons
-Produce to 16:9 with added letterbox, the audio is encoded from MPEG to AC3
-After that I burn the VOB files in the DVD using Clone DVD
Maybe is because the audio is encoded from MPEG 2 channel to AC3? -
It should not make a difference. I suspect that you are using a typical one-click-wonder program that tries to everything, but ends up doing none of it very well.
I can't really suggest a solution, other than to ditch the software for a while and learn how you use th ebest tools for each stage of the authoring process, to see if the situation improves.Read my blog here.
So the better way it`s just to make step by step, encode audio first,save the file and then just burn the DVD?, which programs can I use to do that?
While I learn how to do that I`d use the Ultra DVD creator, altough the sound is 2 channel MPEG
audio sync problem, how to work out progressive audio sync delay
By jolt321 in forum Newbie / General discussionsReplies: 13Last Post: 10th Apr 2012, 21:09 -
AutoGK, Audio Sync problem.
By steve_hawthorn in forum Newbie / General discussionsReplies: 2Last Post: 22nd Dec 2009, 00:39 -
Audio Sync Problem
By lwea2009 in forum Newbie / General discussionsReplies: 8Last Post: 30th May 2009, 15:19 -
out of sync audio problem
By virendra in forum AudioReplies: 2Last Post: 25th Dec 2007, 06:31 -
New (?) audio sync problem
By oldblues in forum ffmpegX general discussionReplies: 3Last Post: 26th Oct 2007, 10:26
