Some of my Avi to dvd files i burn, they turn out to skip, or jerk every couple of seconds. It is only some of my movies, not all of them, so i know its not my disc im using, im using Winavi to convert my movies.
Whats the problem?
Results 1 to 15 of 15
Your problem is WinAVI.
I suspect that you have 23.976 fps source material. WinAVI converts this to 29.976 fps, creating false frames as it goes. This creates the jerking you are seeing.
The correct way to convert this material is to encode it as 23.976 fps and apply 2:3 oulldown to the results. This will allow it to playback correctly.
You can do this either by using a decent encoder, or by using the ocmmercial version of ConvertXtoDVD, which now incorporates pulldown for 23.976 source material. The free version (DivxtoDVD) does not, and suffers the same jerkiness as a result.Read my blog here.
FitCD (free) -> Avisynth (free) -> HCEnc (free) -> DGPulldown (free) -> DVD Author GUI (free)
Read my blog here.
Originally Posted by weejiDonatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
As pointed out in my first post, DivxtoDVD encodes 23.976 material as 29.976 and creates duplicate frames to fill out the missing space. This results in jerky output, especially on pans and zooms, which is the problem the OP is trying to resolve. The only way to truely avoid this is to encode as 23.976 with 2:3 pulldown. ConvertXtoDVD does this, otherwise it has to be done manually or with tools that front end to encoders that can.
Read my blog here.
ive gotten ConvertXtoDVD but i dont see any opetions to do "23.976 with 2:3 pulldown"
tested it with a movie, looks fine on comp need to do a burn test *stupid demo thing box msg* $30 is too rich for my blood...too bad the early free version doesnt do it..or does it ?
Dvd to .avi audio problem
By gartzo in forum Video ConversionReplies: 5Last Post: 21st Feb 2012, 09:04 -
DVD to .avi problem
By poir420 in forum Newbie / General discussionsReplies: 6Last Post: 16th Nov 2010, 17:12 -
Downloaded AVI to DVD problem
By karlh10 in forum Video ConversionReplies: 6Last Post: 5th Aug 2008, 14:55 -
Avi to DVD problem
By slipknotkod in forum Video ConversionReplies: 2Last Post: 30th Jul 2008, 01:57 -
dvd to avi problem
By hobmob in forum DVD RippingReplies: 7Last Post: 2nd Sep 2007, 17:40
