Hey guys, i've been having problems with burning a DL dvd. I have authored the DVD using DVD-Lab Pro and then use Nero 7 to burn to Verbatim 2.4x DVD+R DL using my Sony DW-D56 DVD-writer.
The problem is with the menu when played back in my Sony DAVS-500 dvd player.
The menu does not appear on screen and i cant seem to see anything, however if i press play the movie plays fine, but its when i try to see the menu it just doesn't work??
Anyone with any advice or tips would greatly appreciated
Results 1 to 9 of 9
So you are putting in the disc,and when you do,nothing happens. Or does the disc start playing by itself ? I am not familiar with DVd-Lab Pro but i know in TMPGEnc DVD Author there are setting of what to do first (ie: play first track,go to main menu,go to track menu) so i would guess that somewhere you are missing a setting.
Tom
When i put the disc in, it goes to the menu and thats what i have set it at, but the problem is i cant see the menu, or it doesn't show up for some reason!!
But if i press the play button at this point the movie will play !! Unfortunately i have 11 episodes of a TV program on the DVD, and i need the menu to navigate !!!
Please help -
Does the menu show up when you play it on your PC at all ?
Explore the VIDEO_TS folder and be sure there is a VIDEO_TS.VOB file which is normally the menu file. then just click on it and see what happens.
Tom
Does anyone or should I say is that anyone that can possibly help me with liquid 217 it is a very good program I would like to run it but I know nothing about computers or programs is anyone that the possibly help me with this problem please get back to me. It's going to be necessary for e-mails photographs and pictures. Guides only to have to story on the the whole story.
Well,the first thing you want to know about forums and such is that what you just did is commonly referred to as a "threadjack",that is posting something completely off topic for your own benefit with an off topic question.Originally Posted by whitepirate
You need to go to the main forum page and start your own topic,or "thread",and ask for your help there.
Good Luck !!
Tom
audio problems when burning a DVD
By cosypete in forum Authoring (DVD)Replies: 3Last Post: 9th May 2010, 19:23 -
Problems with DVD burning for backup
By DDieggo1000 in forum Newbie / General discussionsReplies: 3Last Post: 3rd Jul 2009, 00:36 -
DVD burning problems
By Tbag in forum ComputerReplies: 13Last Post: 3rd Sep 2008, 16:55 -
DVD download Burning problems
By completeidiot in forum Newbie / General discussionsReplies: 1Last Post: 6th Jan 2008, 06:53 -
By ssaamm in forum DVD & Blu-ray WritersReplies: 10Last Post: 22nd Sep 2007, 01:11
