I have used DVDFab Decrypter to Rip "The Lion the Witch & the Wardrobe" to HD, then try to use DVD Shrink, but when I do the buffer steadly climbs to 1.1 G, & comes to the Insuffient memory error. This also happens with "The Brothers Grim", "Flight Plan", & "The Legend of Zoro". I've closed out mostly all programs & still the same error. I've also backed-up plenty of new released DVD's, so it's not a Hardware or Software problem. Can anyone help?
Ok I have about 600-700 DVD backups, so I kinda know what I'm doin. My setup is DVDFab Decrypter, DVDShrink, DVD Decrypter. I have 200HD with 150G of free space & 1 GB of Ram.
I'd rather die on my feet.
Than die on my knees. -
Try loading dvd43 andfollow instructions. You should be able to go directly to shrink when dvd43 is loaded. One thinf I have found is that you can't use dvdfabdecrypter when dvd43 is running, you have to turn it off first. Nyah Levi
For Narnia: dvdfabdecrypter to rip it, then when you use dvdshrink, re-author and extract the movie only. If you try to shrink the entire dvd, you will get insufficient memory error.
I have 1 GB of ram as well.TANSTAAFL -
Thank you both very much I got it to work
if you run the movie through VobBlanker after you rip the movie you should not have any problem with dvdshrink. i used anydvd then vobBlanker and then DVD2ONE V1.52 to backup the movie
dvd shrink error out of memory???
By carlos28355 in forum Newbie / General discussionsReplies: 17Last Post: 26th May 2014, 00:04 -
DVD Shrink error - Out of Memory
By xoADAMox in forum Newbie / General discussionsReplies: 5Last Post: 19th Dec 2011, 10:32 -
Vegas 8 - "System low on memory. You may be able to reduce memory usag
By sdsumike619 in forum EditingReplies: 12Last Post: 12th Nov 2009, 06:16 -
DVD Shrink-short of memory
By Mållgan in forum Authoring (DVD)Replies: 9Last Post: 29th Dec 2008, 07:02 -
DVD Shrink not releasing memory when done?
By SCDVD in forum Newbie / General discussionsReplies: 1Last Post: 28th Aug 2007, 11:12
