I cleared a paper jam under the cartridge, re-installed the cartridge about 20 times and it will no longer acknowledge that the cartridge is present (install cartridge is a constant message). There is no paper in any other section, the paper that was jammed came out cleanly in one piece. The print job was was from tray 2 and the registration-plate is in the correct position.
Would really appreciate advise from any member who has had a similar problem or knows why this is happening.
I would really appreciate any help.
Paper jam's are one issue people should be wary of , esspecially with modern printer's .
The golden rule is : Never try pullin paper jams free by hand .
Turn printer off , and back on , when roller's engage , you can then use some pressure and pull gently to clear jam .
Doing it any other way will cause issue's with the drive gear's , and printer will nolonger function correctly .
As for your "no cartridge error"
Check with your printer's manufacturer for how to reset the printer ... esspecially such thing's as printer count reset .
Another area , is you might have distrubed the printer head itself , and it is nolonger properly seated into position .
Remove cartridge , remove print head , check there is nothing in between the print head's electrical contact's and those on the printer itself , which I have seen before ... it dosent take much .
If clear , reinsert printhead , reinsert cartridge , power unit off .
Now perform "new ink cartridge install routine" , bypass the actual removal and reinsert of cartridge part , and allow printer to go through normal motion .
If now succesfull , proceed with software printer head clean , then alignment , followed by print test .
As with any electronic equipment , it should only be connected to an appropriate power board with spike protection ... otherwise your investment can easily be damaged .. which is not covered under warrantee .
Should this fail , as mentioned above , you should visit the printer's manufacturer for printer help ... canon and epson here in au do list the reset info .
Second last : Should all this fail , you may consider a possibility that the printer may be fine , but it may also be related to the printer software having the issue , which is another common problem .
Uninstall all associated product's that came with printer , then uninstall the driver's for it ... reboot pc .
Reinstall driver's for printer , and try accessing it once more .
Last : If this failed , try taking it to another pc and see if it work's there , if it dose , then something , either hardware or software on the original pc is in conflict and need's to be located and sorted .
Should printer still have issue on second pc ... then it's broken , and need's to be actually repaired ... if under warrantee , good ... if not , your up for a new one . -
Hi Bjs,
Have been off for a few days and have just seen your reply, thank you, I'll try your suggestions one by one and let you know if I do get it going again.
Cheers,
Bob
HP Laserjet 2300dn Printer HELP needed
By blinky88 in forum ComputerReplies: 13Last Post: 29th Oct 2010, 12:26 -
Best place to buy Laserjet Toner?
By pred02 in forum MediaReplies: 6Last Post: 5th Aug 2009, 07:19 -
HP deskjet printer f2275 ink cartridge problem
By honda900fz in forum ComputerReplies: 9Last Post: 28th Jun 2009, 14:19 -
PDF Printer won't install.
By Poppa_Meth in forum ComputerReplies: 4Last Post: 18th Mar 2009, 05:46 -
Help PDF printer driver install
By jollyjohn in forum ComputerReplies: 3Last Post: 5th Mar 2009, 09:18
