Hello, I've made a small freeware tool (DLL) that saves information from AVI videos to the clipboard. This is handy if you want to post AVI information on websites, forums or make a database of your AVI collection. It's also possible to view the AVI information or to batch save the information of all AVI videos in a folder to text files.
There are two output modes: "Normal" and "Template".
With "Normal", the AVI information will be saved as a list.
With "Template", the user can make a custom template and use specific variables, which will be replaced with the AVI information.
AVI2Clipboard adds an entry to your Explorer context menu, which will only show when you right-click on a file with an .avi extension.
Download link: http://www.nazik-building.com/~Wantos/download.php?id=AVI2Clipboard.rar
Results 1 to 1 of 1
Possible to transfer avi from Nikon Coolpix L19 w/o the Nikon utility?
By brassplyer in forum Capturing and VCRReplies: 2Last Post: 4th Jan 2011, 17:28 -
Simple MKV file and info given -Need it in AVI
By cyberlion in forum EditingReplies: 2Last Post: 15th Aug 2010, 05:29 -
How do you find video info from partial avi?
By JoeBolden in forum Newbie / General discussionsReplies: 7Last Post: 14th Apr 2009, 19:48 -
Extracting Closed captions info from AVI
By arikp in forum Video ConversionReplies: 1Last Post: 16th Jul 2008, 12:16 -
AVI2Clipboard is not vista-compatible... any other tools?
By nattawat in forum Newbie / General discussionsReplies: 1Last Post: 3rd Jul 2007, 12:30
