I had previously setup TMPGenc to perfect functionality. however, just had to reformat my whole pc...had been a long time since, and so I totally forgot the settings. I have now set up TMPGenc PLUS under the environmental settings like so:
Directshow multimedia reader +3
AVI2(opendml)... +1
AVI vfw compatibility 0
MS MPEG1 decoder 0
Wave file reader 0
BMP/PPM....reader -2
TMPGenc project reader -2
Whenever I try and encode an Xvid Avi, it'll crash under the source code....
I have the Xvid and DIVX codecs installed....what more should I be doing?
Here try this link:
https://www.videohelp.com/tmpgenc#problems
If TMPGEnc freezes or crashes when converting or you receive errors such as
Unexpected decimal point calculation
Illegal floating decimal point calculation order
Write error occured at address 77F83AED of module "ntdlll.dll"
Try first to change the directshow codec reader priority settings in TMPGEnc under Option->Environmental settings->VFAPI plug-in and right click on the DirectShow Multimedia File Reader and increase the priority to 2 or to the top of the plugin-list and try reopen the video.
If that doesn't help try repair/fix the video source, you find video repair/fix guides here (Downloaded video files could have bad/corrupt video frames that could cause crashes).
There are more suggestions than that one paragraph in the link. I remember having some problem reading a avi and I believe I had to change the priority of one of the settings similar to the recommendation above. Worked fine afterwards. Good luck - a little reading should find what you need.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
thig is I already have the Direct show plugin set up to the highest priority...video source seems to be fine
IRE settings
By Leoslocks in forum DVD & Blu-ray RecordersReplies: 112Last Post: 25th Sep 2015, 15:48 -
Are my capture settings ok ?
By smartel in forum Capturing and VCRReplies: 107Last Post: 29th Mar 2012, 11:13 -
Questions regarding recording settings and compression settings
By so in forum Newbie / General discussionsReplies: 2Last Post: 6th May 2011, 08:45 -
Best Settings
By devdev in forum DVD RippingReplies: 2Last Post: 26th Jan 2009, 10:46 -
HD Settings
By kiwikiwi in forum EditingReplies: 9Last Post: 13th Dec 2008, 16:20
