I just bought this burner. I wanted to get into the DL DVD-Rs. I bought media RiDATA DVDR+DL Speed 2.4x. (Which is recomended on the Plextor site)
I have 3 movies (no menues) that I have Shrunk on my hard drive using DVD shrink 3.2. I then took my TMpgenc dvd aurhor 6.1 created a new dvd/menu showing the 3 movies. It was about 7 gb. Authored the new dvd onto my hard drive.
Pulled up Nero 6 (that came with the plextor burner) to burn the movies. It seems that all goes well with layer one.. but it seems to fail at layer 2? I have been able to burn CD's and 4.7 DVD R- & + fine.
Here are the last few lines of the log:
10:06:50 PM #33 Phase 127 File dlgbrnst.cpp, Line 1832
Generating DVD high compatibility borders
10:09:04 PM #34 Phase 129 File dlgbrnst.cpp, Line 1832
Generating DVD borders completed successfully
10:09:04 PM #35 Phase 67 File dlgbrnst.cpp, Line 1832
Burn process failed
Thoughts on if the problem is the burner, media, or the way the movies are shrunk, other?
I have burned many a DVD and Authored many. But Im still a newbie compared to folks on this site. Thank you.
Nero has a known issue with burning DL media. As you have already figured it, the issue occurs at the layer break. I don't recall if there is a fix for v6 or if it is fixed in v7. Most of the suggestions that I have seen were to use a different burning software.
Google is your Friend -
Do you have a suggestion on burning software? I tried to use the burning fuction in dvd author and got the same error. Because on Nero.. you are right it seemed to stop at the layer 1-2 break.
Good thought...
Plextor PX-B310U
By ruktuim in forum DVD & Blu-ray WritersReplies: 1Last Post: 29th Apr 2009, 13:46 -
Problem burning data DVD using Nero 6 burning rom
By thebluekey_17 in forum Newbie / General discussionsReplies: 3Last Post: 19th Feb 2009, 14:14 -
Plextor PX-AV200U or ???
By wtsinnc in forum Capturing and VCRReplies: 4Last Post: 11th Nov 2008, 13:46 -
Plextor PX-760A
By SCDVD in forum DVD & Blu-ray WritersReplies: 1Last Post: 24th Aug 2007, 01:24 -
Burning tracking problem or software problem???
By yogart in forum Authoring (DVD)Replies: 2Last Post: 24th May 2007, 13:39
