I have some old VHS tapes of some gymnastics guides and they look terrible. I captured first in mpeg and that looked aweful. I decided to capture in the panasonic dv codec so I can do some more extensive filtering and noise removal but I need some help. I know how to use avisynth and virtual dub if that helps. I even have a very very short clip here if you want a sample of that I'm trying to restore.
backhandspring.avi
Multimedia Design student getting an AAS in Springfield, Oregon. I like Gymnastics and DVD authoring. I think the two go nicely together.
FYI the link doesn't work.
Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
since you know how to use vdub - capture with it in uncompressed avi or using codec of your choice, whats your problem? Once you have it on your hdd you'll clean it up and do any other enhancements easily.
check out the guides section - i think smurf have made some capture guide for noobs, or he had some good tips on his website iirc
edit:
I meant user with nick *LordSmurf* ofcoz -
If you can capture them in DV format, it may be a good choice. I've used that before for extensive editing.
You said you need help. With what specifically? Your screen shot doesn't work.
There are a lot of VD filters. Look to http://neuron2.net/ for them
Give us some more info.
Best UK PAL VHS / D-VHS machines for digitising old VHS tapes
By pauldsc in forum RestorationReplies: 8Last Post: 6th Jan 2012, 10:21 -
DVHS VCR performance with EP speed tapes and VHS-C tapes?
By NJRoadfan in forum RestorationReplies: 13Last Post: 8th Apr 2011, 21:36 -
For VHS/S VHS tapes 10 - 20 years old what aspect ratio should I use 3:4 ?
By fuzzblaster in forum Capturing and VCRReplies: 1Last Post: 10th Sep 2010, 17:27 -
Digitizing old VHS tapes: Anything Else to Look Out for?
By darkarn in forum RestorationReplies: 6Last Post: 29th Aug 2010, 03:54 -
moldy and old vhs tapes
By valred in forum Newbie / General discussionsReplies: 5Last Post: 13th Apr 2009, 15:20
