What program is the best?
I have read about AutoGK and that sound good but I have also read that older version have spyware inside and that is something I dont like at all.
FairUse Wizard have a Lite version that is free but if I buy it I can create better quality Xvid
I like to have one program that I can easy use.
I prefer FairUse Wizard for easy of use. You just rip the DVD to the hard drive with DVD Fab Decrypter and run FUW to do the conversion.
AutoGK is a good program, can probably give you somewhat better results, but I find it harder to use. It does have more options and controls than FUW.
But why not try both and see which you prefer? FUWs freeware version is essentially the same as the payware, it just limits the Xvid to 700 MB, which is fine if you want to put them on CDs. -
I'll vote for AutoGK. No spyware any more (and when there was, there were clear instructions on how to remove it). Pretty simple to set up - make sure to look at the guides for it - https://www.videohelp.com/guides?tools=452&&archive=%25 .
If in doubt, Google it.
xvid to mov program?
By whoisquilty in forum MacReplies: 0Last Post: 30th Jul 2010, 12:35 -
Program for converting DVD to Xvid with 3 audio tracks ?
By Noahtuck in forum Video ConversionReplies: 2Last Post: 27th Jun 2010, 00:17 -
HELP Please - Best Program for DVD to DivX/Xvid to run on 64bit win7
By Jorocketoz in forum DVD RippingReplies: 7Last Post: 4th Feb 2010, 05:39 -
Can anyone recommend at good program for converting DVD to Divx or Xvid?
By gbgunner in forum DVD RippingReplies: 13Last Post: 10th Nov 2007, 17:18 -
xvid wont load in program
By dvdhouse111 in forum SVCD2DVD & VOB2MPGReplies: 8Last Post: 6th Jul 2007, 04:26
