If on my computer I record mp3s to a dvd can I play them back on a Panasonic s29 or will it only play them if recorded to a cd?
Basically...no.
And...you don't have enough MP3's to fill a DVD...I've tried..
Yeah very few dvd players that play mp3 cd discs can read from a dvd with mp3 files on them. Most will see a dvdr and expect video on them. Though maybe a few of the divx/xvid players will read mp3 on dvds, don't know for sure though.
And @ hech54 - what do you mean??? I have 5.5gb of mp3's on my computer, that would take two dvd'rs. And that's after I recompressed about half of them to mp3pro @ 64kbps (half size of 128kbps with the same quality
Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
Hi,
The problem of writing hundred of songs inside a DVD is not only to find a DVD player able to play them but the navigation through the disc.
Have a look to this link: http://www.dvdr-digest.com/articles/32_1.html
Paco -
Does your player support MP3 playback ??Originally Posted by LS1
If not, no.
If yes, yes.
Originally Posted by hech54
I do.
If they are capable of MP3 playback they will, they only expect video on a dvdr if it is a video disc and has the compatible video format on them or a video_ts folder.Originally Posted by yoda313
I have burned tons of folder's each with their own MP3's in them and straight mp3's with no folders to dvdr and they all play back fine on my pioneer standalone.
If you don't want to feel left out just reencode your mp3's at a higher bitrate. Or convert them to wav and you'll be able to easily fill a dvdrOriginally Posted by hech54
contrary to popular belief, though, reencoding mp3's is NOT a good idea, it does butcher the quality considerabaly, and if your using that lousy mp3 pro, it will play back on your output device with the same quality of a standard mp3 of the same bitrate....generally speaking, not a good idea......all depending on exactly how much you care about the audio quality, and if your player supports this, you may just be better off ripping the audio cd's to wav or just rip to mp3.....for god's sake dont reencode the mp3's....it's the same type of idea as video....just because your using a "better" codec doesnt mean that your not still losing quality.....
Playing HD MP4 Files From Disc Playback Issues?
By zombie1 in forum DVD & Blu-ray WritersReplies: 5Last Post: 5th Nov 2011, 12:41 -
Playing a 30p AVCHD disc
By Michael33 in forum Authoring (Blu-ray)Replies: 0Last Post: 16th Aug 2011, 12:40 -
Creating a DVD using VOBS & MP3s
By ZenFrog76 in forum Authoring (DVD)Replies: 4Last Post: 17th Oct 2009, 04:00 -
mp3s to a dvd
By AeR0 in forum AudioReplies: 8Last Post: 2nd Aug 2008, 17:48 -
What software should I use to extract DVD audio and convert it to mp3s?
By maccaneer in forum MacReplies: 2Last Post: 4th Sep 2007, 19:03
