Hello all,
Got a quick question. Im thinking the answer is no but I'll ask anyway. Ive done some searching but couldnt find anything specific.
Can one do "batch" converting? By that I mean .. I have about 60 avi files, all with the same specs, that I would like to put on dvd's. From what I have seen, the converters run on the assumption that if you load say 6 files into said program, THATS what you want on the dvd and will convert them accordingly.
I am going away for the weekend and would like to know if there is a conversion program that I can load all 60 files into and select an output file size for EACH individual file (or by batch, whichever) and then when I get back, I can choose the 5 or 6 files that total up the amount of a dvd, and burn them as I see fit.
Is that possible?
Thanks in advance.
LG
Most dedicated encoders can do this on their ear - my own experience is with TMPGEnc Plus and I know that this can do this fairly easily with use of the TMPGEnc Batch List Creator.
TMPGEnc Batch List Creator 3
http://www.videogeneration.com.au/batchlist.htm
I would suggest setting up one file exactly how you want them all and then saving the template to a custom template. Also be careful of specifying the root of any of your drives (for example, c:\) as the destination for your output files.
The best way IMHO would be to do some rough calculations using https://www.videohelp.com/calc.htm to ascertain what bitrate you need to use to fit x AVIs per disc (use the total running time of the AVIs added together). Then configure the template to use that bitrate.If in doubt, Google it.
Batch Converting ASS to SRT
By sickonsin in forum SubtitleReplies: 5Last Post: 30th Apr 2011, 18:12 -
Batch Converting MOV Files
By thomasj in forum LinuxReplies: 3Last Post: 25th Dec 2009, 15:50 -
Batch converting...
By finey in forum Video ConversionReplies: 6Last Post: 31st Jan 2009, 18:01 -
Batch converting
By Dave H in forum SVCD2DVD & VOB2MPGReplies: 8Last Post: 3rd Nov 2007, 07:50 -
Converting MPG to AVI type2 (batch)
By statman24 in forum Video ConversionReplies: 8Last Post: 19th Jul 2007, 05:30
