I want to update my computer and i need a pci exp card but i don't want to purchase another AIW Card , this time , for PCI EXP.
So ,Exist a AIW card for pci (not express) with the theater 200 chip ?
It's for capture video uncompressed.
I'm not sure you can find them new anymore, but what you are looking for is AIW VE.
http://www.ati.com/products/radeon7500/aiwve/index.html -
You can get a nice PCI card from Sapphire using a Theater 550 chip:
http://www.newegg.com/Product/Product.asp?Item=N82E16815117603 -
Can the Theater 500 capture using an AVI format or only mpeg2?
Compatible with virtualdub?
and can capture pal format?
PCI Express 2.0 Compatibility
By Teutatis in forum ComputerReplies: 3Last Post: 28th Apr 2009, 18:36 -
PCI-Express sound card
By leesider in forum AudioReplies: 6Last Post: 2nd Dec 2008, 02:38 -
Problems with Pal-60 capture using ATI AIW 2006 PCI express Radion X1300
By DB83 in forum Capturing and VCRReplies: 2Last Post: 6th Aug 2007, 17:49 -
PCI/PCI Express 1x usb 2.0 card with 2 internal usb inputs
By SIRCOOKS in forum ComputerReplies: 0Last Post: 24th Jun 2007, 12:58 -
Controller card - PCI Express
By mike909 in forum ComputerReplies: 7Last Post: 5th Jun 2007, 09:34
