hello,
I have a dvd that has been converted to vobs from avi but the audio isnt very loud. Is there a way I can make the audio louder even though I dont have the original avi file anymore? Do I have to convert back to avi first?
Results 1 to 19 of 19
No, just extract audio from VOBs, edit audio, reauthor with old video, new audio.
/Mats -
Originally Posted by mats.hogberg
Just a clue will do, I love a challenge? -
Couple of questons?
When I setup tmpgenc what audio setting do I use CBR-linear or mpeg 1 or vbr-linear or mpeg 1? I assume I just let tmpgenc create two seperate files m2v and wav???
Also what audio editor do you suggest and what exactly am I doing in the audio editor?
Thanks once again -
/Mats -
Okay I had never seen that option in tmpgenc before because I had always just started with the wizard.
As for the audio do I load it into audacity and then click the "Make audio louder button" or something? Im just not quite sure of the steps involved.
One more question, when I ran the movie through vob2mpg it created two files. I ahve been working on these two files. Is this okay or should I join them somehow to create one file?
Thanks again for the help. -
Ok open audacity. Click file-open. Choose the directory you saved the audio file in and open it. Then follow these steps:
After its been increased then save it as a new file. You'll have to experiment to see how much you need to increase the volume.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
When I try to open the audio from the second file it just gets half way and then nothign else happens. hats going on with this?
One question do I have to covnert the audio back to ac3?
I used PX3 AC3 to WAV and set it to increase the volume when it created the wav file. I was going to just use tmpgenc express and put the new wav file in as the audio. Will this do or should I convert the audio back to ac3? -
This is not going so good. I used px3 to convert the ac3 to wav and increased the decibels to make the audio louder. I then tried to convert these wav files back to ac3 with ffmpeggui but when I try to select the source files the two wav files arent listed. They dont even have a wav file extension even though they play okay in wmp. Its as if there not audio files.
Also Im not sure if I should use tmpgenc express or tmpgenc dvd author? -
Hey Trueman, when you use PX3 AC3 to WAV remember to add the ".wav" extension with your output file name. Sorry, I should have warned you. For instance: "yourwav.wav" not just "yourwav".
Then, just load it into ffmpeggui & set a bitrate (192-256, I tend to use 224).
You can use TDA for authoring, yes.
Good luck!
Increasing Audio volume on AVI/DivX/Xvid with AC3 Audio
By Spacedementia87 in forum User guidesReplies: 21Last Post: 24th Dec 2021, 07:21 -
Increasing Video Volume
By edlimym in forum Newbie / General discussionsReplies: 2Last Post: 24th May 2010, 06:41 -
Increasing volume in GKnot
By Fire Foxer in forum EditingReplies: 6Last Post: 7th Aug 2009, 08:08 -
increasing volume in mp4 video
By snafubaby in forum Newbie / General discussionsReplies: 2Last Post: 27th Jan 2008, 00:05 -
increasing the volume of ac3 files
By virendra in forum AudioReplies: 4Last Post: 1st Nov 2007, 03:25
