Hi, I need help...
I downloaded a movie a few days ago and it doesn't play properly - it's 'jumpy' -.-
ever since I downloaded that movie, my other movies started doing the same - being all 'jumpy'
The files wont play on certain software, only Realplayer and Windowsmedia. When Realplay searches for updates to sort the problem out a message appears saying there is no addon to support the file :S
Just wondering if anyone could help me?
Cal-dizzle
If you have windows XP, do a system restore to a date before you downloaded the problem movie.........
This often gets me out of trouble........... -
I would be surprised that a video would do this type of damage, however if you also installed new codecs, or god forbid, a codec pack, in order to play it, then it would make sense.
Start by identifying what type of video it is. AVICodec or MediaInfo would be a good place to start.
I would also use codecsniper to find and remove any broken codecs.
If this doesn't help, you can still use system restore, but I think that is a drastic step at this stage.Read my blog here.
Deleted videos retrieved, wont play!?
By seskill in forum RestorationReplies: 17Last Post: 13th Aug 2015, 16:28 -
Can't Render Videos Properly After Reformat
By abdullahisme in forum EditingReplies: 7Last Post: 12th Apr 2011, 09:50 -
certain videos do not play properly
By julvar in forum Newbie / General discussionsReplies: 5Last Post: 2nd Apr 2011, 15:55 -
the sound in my converted videos IS there, but some programs wont play it?
By extent in forum Video ConversionReplies: 8Last Post: 30th Aug 2010, 17:38 -
Videos not playing properly - Codec Problem - HELP PLEASE
By Man-bear-pig in forum Software PlayingReplies: 1Last Post: 10th Feb 2008, 00:59
