My brother is having an issue. He has the Panasonic DVC80 camcorder and he is using windows xp pro with SP2. When he plugs in the camera...the usb will act like it sees it but really it doesn't. He gets the sound like a usb has connected but that is it. He has uninstalled and reinstalled drivers. He is using Pinnacle Studio 9 Movie Box Deluxe along with Adobe Premiere 1.5.
Sometimes he can get it to recognize and sometimes he can't. It's weird. Any ideas???
Try another cable
Port may be partially blown especially if you're plugging stuff in with the comp on -
Most camcorders use Firewire not USB to transfer video to the PC so just make sure you follow the manual before drawing conclusions too early. You can connect both directly and control camcorder from the PC capture program no need to go via Moviebox. Quality will be as recorded plus it makes editing a breeze. If you have issues with getting stuff captured via Moviebox then there is an issue with Moviebox installation or drivers, nothing to do with your camcorder.
Pinnacle Studio can handle any firewire camcorder with ease giving access to all transport controls right from your computer screen. Check your Panasonic manual first.
You would probably need a 4-6 firewire cable (as opposed to 6-6 regular one).
Old Sharp VL-NZ50(U) not recognized by windows!
By PETROSMARKOS in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 26th Jan 2012, 11:59 -
Need Help with VOB files not recognized by windows/Cannot open
By cpayne76 in forum RestorationReplies: 9Last Post: 25th Dec 2011, 17:04 -
Intensity Pro firmware update problem on windows 7 pro 64Bit
By ulva in forum EditingReplies: 1Last Post: 5th Oct 2011, 08:00 -
VOB files under 50K not recognized by Windows applications?
By will7370 in forum Newbie / General discussionsReplies: 5Last Post: 31st Aug 2009, 12:53 -
DVDRW not recognized by Windows XP
By bmwracer in forum ComputerReplies: 38Last Post: 11th Sep 2008, 21:33
