Question
I've got an Audiovoxx 9900 Cell Phone. Looked everywhere for a free ringtone of the tones sequence from the soundtrack Close encounters of the 3rd Kind, and I can't find one.. Thinking is it possible to rip that portion from the soundtrack of my DVD copy of the Movie, and convert it somehow to a ringtone? And if it is possible, how do I get it into my Cell Phone?
unequivacably stupid when it comes to Cell Phones....
http://www.ringtonesgalore.co.uk/tones/movies/close-encounters-of-the-third-kind/close...he-third-kind/
http://www.logogo.com/ringtones/polyphonic-theme-close_encounters_of_the_third_kind/
http://www.arcadeathome.com/dl.phtml?pintables/CloseEncountersV2_3.zip|
http://www.yugatech.com/ringtones/ringtone-composer/close-encounters-of-the-third-kind/
the five notes the scientists play are G, A, F, (octave lower) F, C. When they arrive at the tower and are attempting communication, the notes they play are B flat, C, A flat, (octave lower) A flat, E flat."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
BJ_M, you da man... Thanks for your expertise and seeking skills,
mucho gracias, m'friend..
Do you put your cellphone on vibrate or do you use a ringtone?
By yoda313 in forum PollsReplies: 32Last Post: 8th Dec 2025, 10:58 -
How to convert FLV videos and resize them to convert them to AVI
By zikegi in forum Video ConversionReplies: 2Last Post: 18th Sep 2011, 00:06 -
Convert AVI (miniDV) to MKV/MP4, large files only convert partially
By Video Eddie in forum Video ConversionReplies: 0Last Post: 3rd Jan 2011, 06:44 -
Ringtone
By Johnnylee_hang in forum Off topicReplies: 7Last Post: 12th Jun 2008, 15:06 -
Sci-fi / Futuristic ringtone?
By Poppa_Meth in forum Off topicReplies: 2Last Post: 8th Dec 2007, 11:29
