Ok i was just wondering if i should buy a better svideo cable for when i start recording on my dvd recorder. right now i have a cheap one. Does it matter?
NO, that is just a big bogus to get your money out of your pocket......Originally Posted by mikej3131
Is it a little flimsy one? Go for on that has an obvious amount of insulation and is pretty thick. I've found every good component helps a little. Put them all together and you have a significant improvement.
You have to remember you are talking about ~5Mhz bandwidth, not microwaves.
While I wouldn't buy a $4.50 cable, $20 would be a reasonable amount for a name brand like Belkin for a cable about ~6 feet long with well constructed connectors and decent quality cable. Don't buy into 'mega cable' hype. It's just a piece of wire.
Converting HDTV recordings to MKV - quality issues
By Bully9 in forum Newbie / General discussionsReplies: 24Last Post: 29th May 2010, 13:31 -
TOSHIBA D-R7. Problem with quality of coax cable.
By caddyfleet in forum DVD & Blu-ray RecordersReplies: 6Last Post: 5th Feb 2010, 20:01 -
I cant get Svideo to RCA cable to work on my PC to TV.
By awaisuk in forum Capturing and VCRReplies: 1Last Post: 14th Jul 2009, 14:49 -
Converting VHS to DVD: Higher Quality Recordings
By Deter in forum DVD & Blu-ray RecordersReplies: 10Last Post: 16th Dec 2007, 03:47 -
vga, dvi-hdmi, or svideo best cable for pc to 720p hdtv?
By yoda313 in forum ComputerReplies: 5Last Post: 12th Nov 2007, 21:37
