What exactly does the "aggressive" mode in DVD Decrypter do that the "normal" mode doesn't? Should I be using that mode if I run into a problem disc?
I've had the program in "normal" mode since I started using it, just looking for further clarification, and can't find anything using search. Thanks for any assistance with this folks!
AFAIK this could relate to one of two areas:
1. Physically damaged discs, error retries and that sort of thing
2. Decryption keys, "brute force" mode and that sort of thing
I believe that DVDDecrypter with the right settings can continue to rip by just "skipping" unreadable sectors after so many retries so it may be related to that.
Or it could control the sensitivity behind switching into brute force mode to break decryption of VOBs - over the years I've seen some commercial DVDs require keychecks a ridiculous amount of times.If in doubt, Google it.
Windows 7 Stuck in "read only" mode for USB THumbs and SD Cards etc..
By nerys in forum ComputerReplies: 26Last Post: 1st Mar 2012, 02:03 -
xvid-AVIs won't play until re-saved in "copy"-mode
By Information in forum Video ConversionReplies: 0Last Post: 5th Dec 2009, 09:03 -
"Inserting Dummy Sectors" with DVD Decrypter?
By hiimbored in forum DVD RippingReplies: 3Last Post: 2nd Nov 2008, 23:26 -
Do hdtv owners use the "fill" mode to get rid of "underscan&
By yoda313 in forum PollsReplies: 20Last Post: 11th Jul 2008, 19:02 -
Decrypter "Brute Force" mode can damage the writer, or produce ba
By Bruxo in forum DVD & Blu-ray WritersReplies: 5Last Post: 2nd Dec 2007, 15:26
