Hi, hope someone can help me i keep getting the burn failure message with nero6. i have tried a complete fresh reinsatall of all software and os. tried with different brands of media and still the same. nero log enclosed . cheers in advance.
Windows XP 5.1
IA32
WinAspi: -
ahead WinASPI: File 'C:\Program Files\Ahead\nero\Wnaspi32.dll': Ver=2.0.1.74, size=164112 bytes, created 02/11/2004 12:54:32
NT-SPTI used
Nero Version: 6.6.1.4
Internal Version: 6, 6, 1, 4d
(Nero Express)
Recorder: <LITE-ON DVDRW SOHW-1633S>Version: BPSA - HA 1 TA 0 - 6.6.1.4
Adapter driver: <IDE> HA 1
Drive buffer : 2048kB
Bus Type : default (0) -> ATAPI, detected: ?
CD-ROM: <IDE-DVD ROM 6116 >Version: HD24 - HA 1 TA 1 - 6.6.1.4
=== Scsi-Device-Map ===
CdRomPeripheral : LITE-ON DVDRW SOHW-1633S atapi Port 0 ID 0 DMA: On
CdRomPeripheral : IDE-DVD ROM 6116 atapi Port 0 ID 1 DMA: On
DiskPeripheral : ST3160023AS atapi Port 1 ID 0 DMA: On
=== CDRom-Device-Map ===
LITE-ON DVDRW SOHW-1633S E: CDRom0
IDE-DVD ROM 6116 F: CDRom1
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 74448896 (0) Byte
ShowDrvBufStat : 0
BUFE : 0
Physical memory : 511MB (523564kB)
Free physical memory: 68MB (70168kB)
Memory in use : 86 %
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
7.4.2006
UDF/ISO compilation
15:37:00 #1 Phase 112 File dlgbrnst.cpp, Line 1685
DVD-Video files reallocation started
15:37:00 #2 Phase 114 File dlgbrnst.cpp, Line 1685
DVD-Video files reallocation completed (no file modified)
15:37:00 #3 Text 0 File Isodoc.cpp, Line 6475
UDF document burn settings
Determine maximum speed : FALSE
Simulate : FALSE
Write : TRUE
Finalize CD : TRUE
Multisession : FALSE
Burning mode : DAO
Mode : 1
UDF Mode : UDF/ISO bridge
UDF Options : automatic
UDF Revision : 1.02
UDF Partition Type : physical
ISO Level : 1 (Max. of 11 = 8 + 3 char)
Character set : ISO 9660
Joliet : FALSE
Allow pathdepth more than 8 directories : FALSE
Allow more than 255 characters in path : FALSE
Write ISO9660 ;1 file extensions : TRUE
15:37:00 #4 Phase 111 File dlgbrnst.cpp, Line 1685
DVD-Video files sorted
15:37:00 #5 Text 0 File ThreadedTransfer.cpp, Line 531
ReadBuffer-Pipe got 262144KB of Memory
15:37:00 #6 Text 0 File Reader.cpp, Line 124
Reader running
15:37:00 #7 Text 0 File Writer.cpp, Line 122
Writer LITE-ON DVDRW SOHW-1633S running
15:37:00 #8 ISO9660GEN -11 File geniso.cpp, Line 3312
First writeable address = 0 (0x00000000)
15:37:00 #9 ISO9660GEN -11 File geniso.cpp, Line 3312
15:37:00 #10 Text 0 File Burncd.cpp, Line 3305
Turn on Disc-At-Once, using DVD media
15:37:00 #11 Text 0 File DlgWaitCD.cpp, Line 281
Last possible write address on media: 2298495 (510:46.45, 4489MB)
Last address to be written: 2286111 (508:01.36, 4465MB)
15:37:00 #12 Text 0 File DlgWaitCD.cpp, Line 293
Write in overburning mode: NO (enabled: CD)
15:37:00 #13 Text 0 File DlgWaitCD.cpp, Line 2612
Recorder: LITE-ON DVDRW SOHW-1633S, Media type: DVD-R
Disc Manufacturer: CMC MA - G. AE1
Disc Application Code: 64, Disc Physical Code: 193
15:37:00 #14 Text 0 File DlgWaitCD.cpp, Line 459
>>> Protocol of DlgWaitCD activities: <<<
15:37:00 #15 Text 0 File ThreadedTransferInterface.cpp, Line 847
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 ()
2 indices, index0 (150) not provided
original disc pos #0 + 2286112 (2286112) = #2286112/508:1.37
relocatable, disc pos for caching/writing not required/ required, no patch infos
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 2286112 blocks [LITE-ON DVDRW SOHW-1633S]
15:37:00 #16 Text 0 File ThreadedTransferInterface.cpp, Line 1059
Prepare recorder [LITE-ON DVDRW SOHW-1633S] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc fixated
Tracks 1 to 1:
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 4681957376, ISRC ""
DAO layout:
__Start_|____Track_|_Idx_|_CtrlAdr_|_RecDep_______ ___
0 | lead-in | 0 | 0x41 | 0x00
0 | 1 | 0 | 0x41 | 0x00
0 | 1 | 1 | 0x41 | 0x00
2286112 | lead-out | 1 | 0x41 | 0x00
15:37:00 #17 Text 0 File SCSIPassThrough.cpp, Line 38
SPTILockVolume - completed successfully for FCTL_LOCK_VOLUME
15:37:00 #18 Text 0 File SCSIPassThrough.cpp, Line 83
SPTIDismountVolume - completed successfully for FSCTL_DISMOUNT_VOLUME
15:37:00 #19 Phase 24 File dlgbrnst.cpp, Line 1685
Caching of files started
15:37:01 #20 Text 0 File Burncd.cpp, Line 4145
Cache writing successful.
15:37:01 #21 Phase 25 File dlgbrnst.cpp, Line 1685
Caching of files completed
15:37:01 #22 Phase 36 File dlgbrnst.cpp, Line 1685
Burn process started at 8x (11,080 KB/s)
15:37:01 #23 Text 0 File ThreadedTransferInterface.cpp, Line 2685
Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
15:37:01 #24 Text 0 File DVDR.cpp, Line 2707
Recording mode: Sequential Recording Mode
15:37:01 #25 Text 0 File DVDR.cpp, Line 2863
Start write address at LBA 0
DVD high compatibility mode: Yes
15:37:01 #26 Text 0 File Cdrdrv.cpp, Line 8647
---- DVD Structure: Physical Format Information (00h) ----
Media Type: 0, Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
Book Type: DVD-R (2), Part Version: 2.0x (5), Extended Part Version: 0.0 (0)
Disc Size: 120 mm, Maximum Rate: <not specified> (F h)
Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable
Linear Density: 0,267 um/bit, Track Density: 0,74 um/track
Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
End Physical Sector Number of Data Area: 0 h
End Sector Number in Layer 0: 0 h (LBN: FFFD0000 h, 4193920 MB)
Data in Burst Cutting Area (BCA) does not exist
Start sector number of the current Border-Out: 0 h
Start sector number of the next Border-In: 0 h
Media Specific [16..63]:
00 30 00 10 20 00 00 00 - 00 00 00 00 00 00 00 00 .0..............
00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................
15:37:36 #27 Text 0 File Cdrdrv.cpp, Line 1200
15:37:36.671 - E: LITE-ON DVDRW SOHW-1633S : Queue again later
15:46:26 #28 SPTI -1135 File SCSIPassThrough.cpp, Line 289
E: CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1135)
Sense Key: 0x03 (KEY_MEDIUM_ERROR)
Sense Code: 0x0C
Sense Qual: 0x00
CDB Data: 0x5C 00 00 00 00 00 00 00 0C 00 00 00
Sense Area: 0x70 00 03 00 00 00 00 0A 00 00 00 00 0C
Buffer x02dc5200: Len xc
15:46:26 #29 SPTI -1023 File SCSIPassThrough.cpp, Line 289
E: CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1023)
Sense Key: 0x05 (KEY_ILLEGAL_REQUEST)
Sense Code: 0x2C
Sense Qual: 0x00
CDB Data: 0x2A 00 00 21 6D 40 00 00 20 00 00 00
Sense Area: 0x70 00 05 00 00 00 00 0A 00 00 00 00 2C
Buffer x07450000: Len x10000
0x00 00 01 BA 44 00 66 44 94 AB 01 89 C3 F8 00 00
0x01 E0 07 EC 81 00 00 10 D2 27 30 83 28 06 64 10
0x1F D3 3C 5E 62 F3 73 73 73 73 73 73 73 73 73 73
15:46:26 #30 CDR -1023 File Writer.cpp, Line 311
Command sequence error
15:46:26 #31 Text 0 File ThreadedTransfer.cpp, Line 228
all writers idle, stopping conversion
15:46:27 #32 Text 0 File DVDR.cpp, Line 3103
EndDAO: Last written address was 2190655
15:46:27 #33 Phase 38 File dlgbrnst.cpp, Line 1685
Burn process failed at 8x (11,080 KB/s)
Existing drivers:
File 'Drivers\PXHELP20.SYS': Ver=2.03.02a, size=19840 bytes, created 10/08/2004 10:39:56 (Prassi/Veritas driver for win 2K)
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
Check and update firmware for unit .
Try again .
If you have a friend with another pc using xp , preferably an amd system , try burning on their pc .
Note : On occassion , some unit's dont like intel system's that use the 4 wire power connector , strange , but I have seen this happen ... amd system's dont use the extra connector .
If still stuck , and unit under warrantee , take it back and trade for an lg unit (good) , sony (second) , pioneer (third) . -
it was my first thought to update the firmware Bjs but my drive is a SOHW-1633S BPSA which from reading is OEM and it seems like no 2 people have had the same results flashing it. i don't even know for sure which update to use since it's not supported on the lite-on site. think I'll just get another drive any recommendations would be appreciated
Should'nt all DVD burning be SAO(Session At Once) or is DAO the same?
just an update
used the 1653s csot patched crossflashing multi-colored led. to flash my drive, seems to have cured my problems
DVD Styler Fails to Burn
By mik1 in forum Authoring (DVD)Replies: 1Last Post: 10th Jun 2010, 02:57 -
Samsung 22x drives FAILS every 6th or 7th BURN HELP !! WEIRD !
By rockonvidtrade in forum DVD & Blu-ray WritersReplies: 3Last Post: 13th Feb 2010, 20:55 -
DL+ burn fails with ISO file larger than 7 Gig. Why?
By anubis13 in forum DVD RippingReplies: 5Last Post: 5th Dec 2009, 19:48 -
Asus DVD 2014 L1T Writer fails for DVD +- DL
By fjmr in forum DVD RippingReplies: 8Last Post: 11th Aug 2008, 18:38 -
dvd burn fails in all software authoring programs
By jfrenchu in forum Authoring (DVD)Replies: 8Last Post: 9th Feb 2008, 23:39
