please can someone help me? I have been trying to set up my dvd recorder so I can put onto dvd everything I have on sky + hard drive but I just cant get the configuration. I am something of a simpleton where this stuff is so if someone knows can you keep it simple. in case anyone can help this is what I have
Sony LCD TV with 2 scart sockets(one labelled smart link)
sky + box with 2 scart sockets
cheapo dvd recorder (matsuiDVDR100) also with 2 scart sockets
if anyone knows which permutation to use i will be thankful( could you also specify if poss if it should be scart in or out as well on each connection)
Sky+ box Scart 1 to TV Scart 1
DVD Recorder Scart 1 to TV Scart 2
Sky+ box Scart 2 to DVD Recorder Scart 2
Use fully wired 21 way Scart leads for all connections. To record from the Sky+ box, you'll need to select Line 2 (or AV2 or whatever it is labeled as) on the DVD Recorder. If you select AV2 as the input on your TV, you should be able to watch what you are recording. I say should, because not all units passthrough between Scarts when in operation.
I want to buy and connect a Combo DVD and VHS Recorder/Player. Very Newbie
By AuntGail in forum Newbie / General discussionsReplies: 6Last Post: 1st Jan 2012, 19:54 -
Connect Laptop to DVD/HDD Recorder
By HamishT in forum DVD & Blu-ray RecordersReplies: 5Last Post: 2nd Apr 2011, 23:58 -
Connect VCR/DVD Recorder to PC which has TV Tuner
By Butch1942 in forum Media Center PC / MediaCentersReplies: 1Last Post: 16th Feb 2009, 20:03 -
Will this cable work to connect my Epson S3 VGA port to aHDMI DVD recorder?
By NG in forum Newbie / General discussionsReplies: 2Last Post: 14th Dec 2007, 00:20 -
how can i connect a dvd recorder to a tv with builtin vhs
By ItsMikeMazz in forum DVD & Blu-ray RecordersReplies: 2Last Post: 19th Jul 2007, 13:13
