Results 1 to 9 of 9
  1. Member Sakuya's Avatar
    Dec 2002
    I was drawing a picture in a graphics program and I saved it as a project file. I had been working on it for about 5 weeks! Just now when I saved it, it froze, so I ctrl-alt-del and tried to reopen that project file again. When it opened, I got a blank canvas! All my hard work!
    I checked my project file and it's still 275KB so the data can't be gone right? Is there a system restore? I restarted once and it's still a blank canvas. I have Windows 2000.
  2. Banned
    Dec 2005
    Canada
    check this program msg board, look in temp files for a second copy possibly with "~...", check auto-save options and settings
  3. Member Sakuya's Avatar
    Dec 2002
    I did not find any TMP files with a ~. However, there is a TMP file that was created very close to the time of the crash. What do I do with the TMP file?
  4. Banned
    Dec 2005
    Canada
    try THIS SPECIFIC PROGRAM forums (or Google), you didn't even say what you use... you think anyone can read your mind...?
  5. Member Sakuya's Avatar
    Dec 2002
    It's a Japanese program, ComicWorks600. It doesn't have a forum.
    Aug 2004
    Make a new dummy project and save it.
    Check the file extension of your saved project file.
    Rename the *.tmp file with the project file extension and try to open it.
  7. Member Sakuya's Avatar
    Dec 2002
    It won't open. Which means it's not my file. So it's seriously lost? This sucks. They should really hire better program checkers. And I should learn to backup.
    Redding, California
    You might get lucky with 'Restoration.exe' at
    http://www.snapfiles.com/get/restoration.html
  9. Member Sakuya's Avatar
    Dec 2002
    Thanks. But no luck. Oh well. I think I'm going to buy the less buggy version that's actually released in America. Who knows when that will be because it's so expensive.
