Hi all..
I used to d/l movies frm the net and sometimes i encounter a problem like the video is gud and audio is too low to be heard..
it mainly happens for AC3 audio.. so i d/l AC3 ACM and the problem was fixed..
but now i got some movies and the sudio compression is MP3 and in this too the audio is too low..
i searched this forum to find out solutions but its all mainly on AC3 files..
so started this new post..
need help at once..
TIA
-=[ Prepare 2 B Compressed ]=-
I just use VirtualDub Mod. There is a volume adjustment when you select 'Full Processing' in 'Streams'. Re-encode the audio and use 'Direct Stream Copy' for the video. I believe there is a program that can do it without re-encoding the audio, but can't recall the name.
Here's a link to a thread that discussed that program, I believe. It sounds like you would have to demux the audio, modify it, then remux it with the video, though.
https://forum.videohelp.com/viewtopic.php?t=291777
The method I mentioned is in jimmalenko's post.
Is there a way to make all my .avi files the same volume?
By cyberax in forum AudioReplies: 3Last Post: 23rd Apr 2011, 08:35 -
Low Volume on Playback
By SE14man in forum Software PlayingReplies: 6Last Post: 28th Aug 2010, 12:45 -
Low audio volume
By Daz_uk in forum Capturing and VCRReplies: 0Last Post: 29th Jan 2010, 14:34 -
Youtube: why the low volume?
By kevs in forum MacReplies: 3Last Post: 23rd Nov 2008, 07:07 -
Low volume on flv files
By drwho in forum Video ConversionReplies: 3Last Post: 22nd Jul 2007, 18:13
