Ok i think im getting this recorder and was wondering if anybody has experience with this recorder and its ability to record cable shows off comcasts motorola dvr dct6214 box????
Any help on if this recorder is picky or good with comcast dvr's would be appreciated.
I specifically want to record off the "NFL channel" so that would be even better is someone has tried off this channel but if not, just post your experience with other chanels.
p.s. I want to know the RECORDERS ability to record off these channels, not the recorder plus "a copy protection breaker like TBC" or whatever they are called.
thanks
And does anybody know how i can find what type of copy protection NFL channel uses on their shows. i know how to look for 5c copy protection by going into the menu screen(by the way, NFL channel has 5c) but i dont know how to lok for other copy protection
Closed Thread
I know two people with JVC and Comcast PVR. Not sure on model though. They both use it for pay channels, that I know.
wel i just read this in the dr-m100s manual and the dr-m10s manual :
It is impossible to record onto DVD-R/RW (Video mode) discs
broadcasts that allow you to copy once. The copy once
programs can only be recorded onto DVD-RW discs formatted
in VR mode.
so it looks like im out of luck.
Are there such things i can buy to break this copy protection?
You are paranoid.
CPRM is not even in effect yet. No machine will record it when (if) it does go into effect. You are fucked regardless of what you buy. The end.Want my help? Ask here! (not via PM!)
Mike,
Could you continue the discussion in your original thread, please? It helps keep the forums clear.
https://forum.videohelp.com/viewtopic.php?t=297687
Many thanks!
Cobra
Want to capture from my Motorola DCH3416 DVR
By tpapictures in forum Capturing and VCRReplies: 6Last Post: 14th Jan 2012, 23:30 -
My first post: connrccting a DVD to a comcast DVR to record from ther DVR
By retired_guy in forum Newbie / General discussionsReplies: 10Last Post: 24th Jul 2011, 19:54 -
Look what I found-a Motorola DCH3200 set-top box for use with Comcast cable
By zoobie in forum DVB / IPTVReplies: 7Last Post: 15th Dec 2010, 21:27 -
Motorola HD DVR what can I do with it?
By DirtBikeMike in forum Newbie / General discussionsReplies: 2Last Post: 24th Sep 2010, 07:39 -
Moto DVR DCT3416 from Comcast - can I get the recordings off the DVR?
By jmkeuning in forum Capturing and VCRReplies: 42Last Post: 7th Jul 2010, 18:44
