Has anyone ever had this problem, where it won't find the key? it just kepts going and going for like 10mins, never finding the key. (dvd = Requiem for a dream)
Yes, I also had that problem with a DVD. It turned out that the DVD had some scratches on it and SmartRipper couldn't get the key to access one of the VOB files. I ended up using VOBDEC, a command line app to rip the faulty VOB file by manually entering a key from a previous VOB file - luckily the key codes remained the same.
I think I know what the problem. If you using window XP you have to go to download teh new aspi driver. After finish dling and unzipping. Click the aspi.bat and it install aspi into it and click on aspi32.exe after thatit should work perfect.
Trying to find the DVD ripper with the biggest frame size
By True Colors in forum DVD RippingReplies: 2Last Post: 18th Apr 2010, 22:01 -
Menus not shown in DVD Decrypter or Smart Ripper
By EmpireStrikesBack198 in forum DVD RippingReplies: 2Last Post: 11th Jun 2008, 16:48 -
VCD movies - I can't find a ripper!
By robsamui in forum Video ConversionReplies: 10Last Post: 18th Mar 2008, 07:20 -
Change the key of a song to another key?
By Ikka in forum AudioReplies: 4Last Post: 3rd Feb 2008, 13:27 -
Smart ripper help
By holland11 in forum Authoring (DVD)Replies: 4Last Post: 13th May 2007, 01:15
