I went to a ftp and downloaded a movie..
I ended up with 3 archive folders..
Now when I extract the arcives.. I get
6 files... Now there are 3 parts of the movies, for each part of the movie there are 2 files.. 3 of the files are .dat , and 3 are .cue.
Now I extracted the .cue files and got a folder.. here is what was in the folder
five folers
CDI
EXT
MPEGAV
SEGMENT
VCD
Now MPEGGAV had a .dat in it that was a movie, wich was the movie I wanted.. So I took that .dat file and converted it into 1MPEG..
From there I have a mpeg.. and did what the website said when using NERO.. I get a cd that acts like its gona play but doesnt.. so what am I missing?
anyone?
here is the info I need
What File should I use to make a vcd, are there any newer programs then nero, that may be more easy, and what type of cd do I need to usE? thanks
Firstly, CUE/BIN images are disc images. I don't understand this obssession people have with extracting things out of them to burn. If you do so, you loose any menus, etc., that where in the original VCD.
All you have to do is burn the CUE/BIN image: http://www.geocities.com/medinotes/vcd/burning_cuebin_images.html
As for your playback problem, it sounds like your DVD player wasn't designed to play CD-R/W media. If this is the case, then you will have to experiment with different brands of CD-R/W media to find one that works in your player. Often CD-RW works better in these cases.
If you plan on buying a new DVD player, be sure to buy one that explicitly states in the manual that it is both S/VCD compatible AND CD-R/W compatible. S/VCD compatibility means a completely different thing.
Regards.
Michael Tam
w: Morsels of Evidence
there is hope for 3d after all
By aedipuss in forum Newbie / General discussionsReplies: 19Last Post: 18th Mar 2012, 09:21 -
Hope someone can assist me with my process...
By Cralis in forum Newbie / General discussionsReplies: 5Last Post: 5th Mar 2010, 19:41 -
Any hope for this footage?
By wwaag in forum RestorationReplies: 4Last Post: 13th Sep 2009, 13:06 -
Is 480i the best an average Joe can hope for?
By gigantibyte in forum Capturing and VCRReplies: 32Last Post: 10th Feb 2009, 06:49 -
I hope it's true!!!
By zoobie in forum Off topicReplies: 2Last Post: 15th Dec 2008, 23:21
