Is it possible, like the topic says?
Lately a lot of the DVDs I've been working with have been dual layer DVDs, therefore not fitting on one of my normal DVD's on 4.7GB.
This means I have to compromise the quality, and that sucks!
Any ideas?
Results 1 to 15 of 15
Time to buy some dual layer discs when they are on special. I'm still living off all those Fujis i bought on Boxing day for $8.00CAD/3 pack. No worries about losing quality that way.
The only way to guarantee a 1 to 1 perfect copy is to use DL media or split the disk as already mentioned.No DVD can withstand the power of DVDShrink along with AnyDVD! -
I been trying to break this dvd9 and can't get it i been trying everything..Dvd shrink with anydvd.dvd fab ,dvd rebuilder ,dvd dycrpter.thier is a css on the disk it keeps getting stuck .could any one help please.....
There is than likely a problem with your disk itself. Try some other ripper like the latest DVDFabDecrypter and it is stops in the exact location then it is and error on your disk that can only affect things when you are ripping and maybe not when playing on a set top machine..
data error cycle redudancy error ...when i use dvd shrink always at the same spot
use DVDFAB DECRYPTER to rip to your hard drive then use DVDSHRINK. with the sony discs they have copy encryption codes that DVDSHRINK cannot by pass. DVDFAB DECRYPTER takes care of it. download it from the tools section
Originally Posted by ottosen
Hope it helps you as much as it helped me. 8)
DVD Shrink to a dual layer DVD?
By langham in forum Authoring (DVD)Replies: 7Last Post: 26th Mar 2012, 03:46 -
Ok, best tool for converting dual layer dvds to single layer dvds is?
By burgkev in forum Authoring (DVD)Replies: 5Last Post: 25th Aug 2008, 01:02 -
Splitting 8GB DVD into 2 single layer dvds
By omega_weapon in forum ComputerReplies: 4Last Post: 16th Aug 2008, 11:17 -
"splitting" dual layer to 2 dvd+r?
By tlinehan in forum MacReplies: 5Last Post: 13th Jul 2008, 16:42 -
what dual layer dvds should I be using with the following setup?
By transient_today in forum MacReplies: 1Last Post: 22nd Jul 2007, 15:05
