    Apr 2006
    my volume is PERFECT in everything else BUT the dialogue is VERY LOW when i play dvd's.
    when i rip the dvd's to a divx file the dialogue is perfectly loud and clear. for some reason, when i play dvd's the dialogue track comes out real low.
    i am using VLC and id like to try to get it to work rather than installing a PowerDVD or Theater Tek, etc
    Any thoughts? =)
    you can boooooost the audio with ac3 filter or ffdshow(set it decode ac3 and dts). but you can't use vlc then you need a directshow player like media player classic.
    Apr 2006
    thanks for the reply...sorry if i am a super newb but how do i do that? and if i can't use VLC then what should I use?
