I use DMF to capture from my DV cammer
but the audio allway choppy,I try to set at 44.1khz or 44.0khz,when I use ULEAD VIDEOSTUDIO 5.0 is ok.
my cam is Panasonic pv-dv200d-k
my 1394 firewire card is form DAZZLE DV-EDITOR
can someone help?
Try setting your audio capture settings to 48khz as thats what's needed for DVD authoring. Sounds like DMF is re-encoding the audio from 44.1 or 44 to 48khz and choppy sound is quite common when that happens. TMPGEnc sometimes has tha problem re-encoding audio to a higher frequency.
Ulead DVD Movie Factory 6 Plus
By orientaldragon in forum Newbie / General discussionsReplies: 8Last Post: 2nd Apr 2011, 09:48 -
Movie Factory 6+ with HD-DVD Plugin
By wulf109 in forum Blu-ray RippingReplies: 1Last Post: 25th Oct 2010, 12:20 -
By Ragamuffin in forum Authoring (DVD)Replies: 3Last Post: 6th Oct 2009, 13:22 -
By koberulz in forum Newbie / General discussionsReplies: 10Last Post: 26th Jun 2007, 08:14 -
Ulead DVD Movie Factory 5 Plus Help
By sootylfc in forum Authoring (DVD)Replies: 3Last Post: 21st May 2007, 19:20
