I just noticed when I click on an avi file in my dvd drive, it plays in slo-mo. But if I copy the file to my HD, it plays fine. Is there a setting I'm missing or is this standard operating procedure?
NEC-ND3520
Thx
It's a dvd data disc and plays the DV-AVI's fine in vlc once you let it run thru once. I guess it's caching on my HD. My default is wmp which is playing the same file in slo-mo. They're just short clips each.
My HD's are low on memory. Perhaps this is affecting wmp. I shall free up more space on my OS HD in the meantime.
Thx -
Well, I've noticed this only happens when I've set the disc to burn a non-multi-session. Perhaps it's taking 3.8gb or so and 'stretching it' to fit the whole disc resulting in a slow-mo playback in wmp. Simply setting it to multi-session burn seems to do the trick.
hmmm.... so ya' think it's "stretching" it, huh? more likely it has to do with how fast the dvd player can read/send the info. try being sure if your dvd player has the capability, that you are using ultra dma mode.
It was just a guess...It's not doing it anymore since I switched the settings.
Blu-Ray Player that plays .avi (and other) with external hard drive?
By RushMaster in forum DVD & Blu-ray PlayersReplies: 8Last Post: 26th Dec 2011, 12:51 -
Getting 120fps to render in slo-mo
By simonov in forum EditingReplies: 4Last Post: 16th Dec 2011, 22:08 -
Looking for media player/hard drive that plays mkv files
By julie_152 in forum Media Center PC / MediaCentersReplies: 1Last Post: 14th Aug 2010, 12:48 -
Need DVD Player that plays .avi files
By ukbsktbll in forum DVD & Blu-ray PlayersReplies: 12Last Post: 8th Mar 2009, 08:57 -
Smooth Slo-Mo with HV20 souce
By racer-x in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 7Last Post: 13th May 2008, 12:21
