I used to dvd2avi and save the project, but it has .ac3 as the sound. How can I use that in tmpgenc? If I can't how do I make dvd2avi produce a wave?
Thanks in advance!!!
<font size=-1>[ This Message was edited by: Corta2863 on 2002-01-01 11:23:12 ]</font>
You have dvd2avi set to demux. If you want it to decode the audio set it to decode. (audio\dolby digital...)
TMPGenc cannot accept ac3 files. You could use azid to process the ac3 to wav if you want and then load it into TMPGenc. Many people also feel this produces higher quality audio than dvd2avi.
replace ac3 2ch with ac3 5.1 ch in mkv (and sync)
By umbbra in forum AudioReplies: 1Last Post: 12th Jun 2010, 04:18 -
Convert stereo ac3 with bad channel to mono ac3
By chipsndukes in forum AudioReplies: 7Last Post: 5th Nov 2008, 11:23 -
How to convert AVI/DivX/XviD with AC3 to DVD with AC3
By Baldrick in forum User guidesReplies: 52Last Post: 21st May 2008, 19:22 -
Sync issues after converting AVI (DivX 5/AC3) to MPEG2/AC3
By Greycat in forum Video ConversionReplies: 4Last Post: 25th Mar 2008, 10:24 -
H264 + AC3 + AC3 --> VOB - What is wrong with my command line?
By olik in forum ffmpegX general discussionReplies: 5Last Post: 3rd Feb 2008, 07:06
