Chris,
I've recently come across a problem with converted films 'skipping' as soon as they start playing on my PC. I've got the latest version installed. Last night, I checked the mpg file after the first pass and it was fine so it seems to be something happening after that.
Thanks for any advice, log as follows;
Title: 2.1
Version: 2.1.0.0
Executable: C:\Program Files\BadgerIT\SVCD2DVD v2\SVCD2DVD.exe
Executable size: 2.51 MB
Executable size in bytes: 2633811
Executable CreationTime: 12/03/2006 20:38:32
Executable LastWriteTime: 14/03/2006 07:26:05
Executable LastAccessTime: 05/04/2006 20:34:07
************************* Operating System *************************
Operating System: Microsoft Windows XP Professional
Service Pack: Service Pack 2
Version : 5.1.2600
Windows Directory : C:\WINDOWS
OSLanguage: 1033
CodeSet: 1252
CountryCode: 1
Local: 0409
Total Physical Memory: 0.99 GB
Free Physical Memory: 619 MB
Total Virtual Memory: 1.99 GB
Free Virtual Memory: 1.96 GB
***************************** Computer *****************************
Computer Manufacturer Name: Fujitsu Siemens
Computer Model: GA-8ISXT
System Type: X86-based PC
Computer Name: BLADES-FFB5TVU0
DomainRole: x2c3419cdc9b8e007
Number Of Processors: 2
User Name: BLADES-FFB5TVU0\Dave
***************************** Processor ****************************
Manufacturer: GenuineIntel
Processor: Intel(R) Pentium(R) 4 CPU 3.00GHz
Description: x86 Family 15 Model 2 Stepping 9
CPU Speed: 3GHz
CPU FSB: 200MHz
L2 Cache Size: 0 bytes
CPU Speed: 3GHz
CPU FSB: 200MHz
21:36:18: Logical CPUs: 2
***************************** Time Zone ****************************
Time Zone: (GMT) Greenwich Mean Time : Dublin, Edinburgh, Lisbon, London
****************************** VIDEO *******************************
Name: NVIDIA GeForce FX 5200 Ultra
Processor: GeForce FX 5200 Ultra
Mode: 1024 x 768 x 4294967296 colors
Video Ram: 256 MB
Status: OK
****************************** Drives *******************************
DeviceID: C:
FileSystem: NTFS
FreeSpace: 832 MB
DeviceID: E:
FileSystem: FAT32
FreeSpace: 299 MB
DeviceID: F:
FileSystem: FAT32
FreeSpace: 223 MB
DeviceID: G:
FileSystem: FAT32
FreeSpace: 2.40 GB
DeviceID: H:
FileSystem: FAT
FreeSpace: 248 MB
DeviceID: I:
FileSystem: FAT32
FreeSpace: 947 MB
DeviceID: J:
FileSystem: FAT32
FreeSpace: 622 MB
DeviceID: K:
FileSystem: NTFS
FreeSpace: 10.0 GB
DeviceID: S:
FileSystem: FAT32
FreeSpace: 136 MB
********************* END OF SYSTEM INFORMATION ********************
************************* ProjectMetaData **************************
<SVCD2DVD DateTime="05/04/2006 21:36:19"><AssetSet><Asset ID="ccb614cc-8e35-48be-9230-3627ef1b9203" Path="K:\xxxxx" Filename="BM.avi" /></AssetSet><DVDStructure><TitleSet Name="New Movie" PostCmd="" MenuButtonType="0"><MenuButton X1="0" Y1="0" X2="262" Y2="49" FontFamily="Tahoma" FontSize="28" FontStyle="3">Menu Button</MenuButton><Title Name="BM.avi" AssetID="ccb614cc-8e35-48be-9230-3627ef1b9203" MplexOffset="0" /></TitleSet><DVDMenu Normal="-1" Highlight="-65536" Active="-16711681" ShowPlayAllButton="False" DSOffsetWidth="1" DSOffsetHeight="1" DSColor="0" DSOnOff="True" BackgroundImagePath="C:\Program Files\BadgerIT\SVCD2DVD v2\default.jpg" AudioPath="" /></DVDStructure><Settings><General InitialAssetFolder="K:\Temp" InitialDVDFolder="K:\Temp" InitialProjectFolder="K:\Temp" InitialMenuBackgroundFolder="" DeleteS2DFiles="False" UseDVDShrink="False" /><Menu AudioEncoding="Silence_mpa" DefaultCustomAudioPath="" DefaultCustomImagePath="" TVStandard="PAL" FontFamily="Tahoma" FontSize="28" FontStyle="3" PlayAllText="Play All" Loop="True" EncodeVideo2AudioDuration="False" /><Process AudioEncoding="mpa" Chapters="Every 10 mins" SkipMPA48="False" SkipAC3="True" PanSan="False" MergeTitles="False" UsePulldown="True" PAL2NTSC="False" AVI2PASS="False" AVI2HALFD1="FS" NoBframes_FullME="False" UseCustomMatrices="False" IntraMatrix="" NonIntraMatrix="" TVOverscanPixels="0" /><Program BINExtraction="vcdxrip" VCDGearFIX="False" FastAudioEncode="True" /><Burning BurningMethod="NeroBurner" DVDDrive="PIONEER DVD-RW DVR-107D" NeroWriteSpeed="4x (5540 KBs)" Eject="True" HighDVDCompat="True" VerifyDVD="False" DVDDecrypterPath="C:\Program Files\DVD Decrypter\dvddecrypter.exe" DVDDErase="True" DVDDClose="False" DVDDDontBurn="False" /></Settings></SVCD2DVD>
Processing assets for DVD creation
=================== AV Details ===================
File Size: 1.36 GB
file=K:\xxxxx\BM.avi
FormatName=avi
Num_Frames=193317
DurationInSecs=8061
Duration=02:14:21.8
VideoCodec=mpeg4
Width=592
Height=320
Standard=NTSC (Film)
BitRate=1454
AudioStreamCount=1
Audio1SampleRate=48000
Audio1Codec=ac3
Audio1BitRate=448
Audio2SampleRate=-1
Audio2Codec=NULL
Audio2BitRate=-1
AVI2MPG: 4056kbs Full-D1
21:36:19: Looking for AVI PAR...
Leaving source audio alone.
Pass 1/1: Processing BM.avi
21:36:20: FFmpeg version CVS, Copyright (c) 2000-2004 Fabrice Bellard
21:36:20: configuration: --enable-a52 --enable-gpl --enable-memalign-hack --disable-debug --enable-pthreads
21:36:20: libavutil version: 49.0.0
21:36:20: libavcodec version: 51.4.0
21:36:20: libavformat version: 50.2.1
21:36:20: built on Mar 11 2006 01:37:17, gcc: 3.4.4 (mingw special)
21:36:20: Input #0, avi, from 'K:\xxxxx\BM.avi':
21:36:20: Duration: 02:14:21.8, start: 0.000000, bitrate: 1454 kb/s
21:36:20: Stream #0.0, 23.98 fps(r): Video: mpeg4, yuv420p, 592x320
21:36:20: Stream #0.1: Audio: ac3, 48000 Hz, 5:1, 448 kb/s
21:36:20: Output #0, dvd, to 'K:\xxxxx\BM_S2D.mpg':
21:36:20: Stream #0.0, 23.98 fps(c): Video: mpeg2video (hq), yuv420p, 720x480, q=1-31, 4056 kb/s
21:36:20: Stream mapping:
21:36:20: Stream #0.0 -> #0.0
21:36:20: Stream #0.1 -> #0.1
23:05:12: [mpeg2video @ 0068E248]rc buffer underflow
23:19:35: video:3985520kB audio:440878kB global headers:0kB muxing overhead 1.989537%
23:19:35: AVI2MPG: done.
NTSC(Film)->NTSC: demuxing BM_S2D.mpg
23:19:37: FFmpeg version CVS, Copyright (c) 2000-2004 Fabrice Bellard
23:19:37: configuration: --enable-a52 --enable-gpl --enable-memalign-hack --disable-debug --enable-pthreads
23:19:37: libavutil version: 49.0.0
23:19:37: libavcodec version: 51.4.0
23:19:37: libavformat version: 50.2.1
23:19:37: built on Mar 11 2006 01:37:17, gcc: 3.4.4 (mingw special)
23:19:37: Input #0, mpeg, from 'K:\xxxxx\BM_S2DNTSC(Film).mpg':
23:19:37: Duration: 02:14:19.4, start: 0.500000, bitrate: 4588 kb/s
23:19:37: Stream #0.0[0x1e0], 23.98 fps(r): Video: mpeg2video, yuv420p, 720x480, 7800 kb/s
23:19:37: Stream #0.1[0x80]: Audio: ac3, 48000 Hz, 5:1, 448 kb/s
23:19:37: Output #0, rawvideo, to 'K:\xxxxx\BM_S2DNTSC(Film).mpv':
23:19:37: Stream #0.0, 23.98 fps(c): Video: mpeg2video, yuv420p, 720x480, q=2-31, 7800 kb/s
23:19:37: Output #1, ac3, to 'K:\xxxxx\BM_S2DNTSC(Film).ac3':
23:19:37: Stream #1.0: Audio: ac3, 48000 Hz, 5:1, 448 kb/s
23:19:37: Stream mapping:
23:19:37: Stream #0.0 -> #0.0
23:19:37: Stream #0.1 -> #1.0
23:29:29: video:3985520kB audio:440878kB global headers:0kB muxing overhead -9.960188%
23:29:29: NTSC(Film)->NTSC: Applying Pulldown BM_S2DNTSC(Film).mpv
23:29:30: SVCD2DVD: Convert2NTSC: Converting....
23:53:59: NTSC(Film)->NTSC: Muxing BM_S2D.mpg
23:59:59: INFO: [???] mplex version 2.0.0 (2.2.3 $Date: 2004/01/13 20:45:26 $)
23:59:59: INFO: [???] File K:\xxxxx\BM_S2DNTSC(Film)_pd.mpv looks like an MPEG Video stream.
23:59:59: INFO: [???] File K:\xxxxx\BM_S2DNTSC(Film).ac3 looks like an AC3 Audio stream.
23:59:59: INFO: [???] Video stream 0: profile 8 selected - ignoring non-standard options!
23:59:59: INFO: [???] Found 1 audio streams and 1 video streams
23:59:59: INFO: [???] Selecting dvdauthor DVD output profile
23:59:59: INFO: [???] Multiplexing video program stream!
23:59:59: INFO: [???] Scanning for header info: Video stream e0 (K:\xxxxx\BM_S2DNTSC(Film)_pd.mpv)
23:59:59: INFO: [???] VIDEO STREAM: e0
23:59:59: INFO: [???] Frame width : 720
23:59:59: INFO: [???] Frame height : 480
23:59:59: INFO: [???] Aspect ratio : 16:9 display
23:59:59: INFO: [???] Picture rate : 29.970 frames/sec
23:59:59: INFO: [???] Bit rate : 7800000 bits/sec
23:59:59: INFO: [???] Vbv buffer size : 229376 bytes
23:59:59: INFO: [???] CSPF : 0
23:59:59: INFO: [???] Scanning for header info: AC3 Audio stream 00 (K:\xxxxx\BM_S2DNTSC(Film).ac3)
23:59:59: INFO: [???] AC3 frame size = 1792
23:59:59: INFO: [???] AC3 AUDIO STREAM:
23:59:59: INFO: [???] Bit rate : 57344 bytes/sec (448 kbit/sec)
23:59:59: INFO: [???] Frequency : 48000 Hz
23:59:59: INFO: [???] SYSTEMS/PROGRAM stream:
23:59:59: INFO: [???] rough-guess multiplexed stream data rate : 8429296
23:59:59: INFO: [???] target data-rate specified : 10080000
23:59:59: INFO: [???] Setting specified specified data rate: 10080000
23:59:59: INFO: [???] Run-in Sectors = 89 Video delay = 13019 Audio delay = 0
23:59:59: INFO: [???] New sequence commences...
23:59:59: INFO: [???] Video e0: buf= 0 frame=000000 sector=00000000
23:59:59: INFO: [???] Audio bd: buf= 0 frame=000000 sector=00000000
23:59:59: INFO: [???] STREAM e0 completed @ frame 79559.
23:59:59: INFO: [???] STREAM bd completed @ frame 251929.
23:59:59: INFO: [???] Multiplex completion at SCR=725548763.
23:59:59: INFO: [???] Video e0: buf= 0 frame=251913 sector=00832827
23:59:59: INFO: [???] Audio bd: buf= 14336 frame=251929 sector=00223938
23:59:59: INFO: [???] VIDEO_STATISTICS: e0
23:59:59: INFO: [???] Video Stream length: 1681932288 bytes
23:59:59: INFO: [???] Sequence headers: 4474
23:59:59: INFO: [???] Sequence ends : 0
23:59:59: INFO: [???] No. Pictures : 79560
23:59:59: INFO: [???] No. Groups : 4474
23:59:59: INFO: [???] No. I Frames : 4474 avg. size 50407 bytes
23:59:59: INFO: [???] No. P Frames : 22048 avg. size 32818 bytes
23:59:59: INFO: [???] No. B Frames : 53039 avg. size 13816 bytes
23:59:59: INFO: [???] Average bit-rate : 4054800 bits/sec
23:59:59: INFO: [???] Peak bit-rate : 8765600 bits/sec
23:59:59: INFO: [???] BUFFERING min 15 Buf max 211535
23:59:59: INFO: [???] AUDIO_STATISTICS: bd
23:59:59: INFO: [???] Audio stream length 451458560 bytes.
23:59:59: INFO: [???] Frames : 251930
23:59:59: INFO: [???] BUFFERING min 35 Buf max 6755
23:59:59: INFO: [???] MUX STATUS: no under-runs detected.
23:59:59: Done: Processing assets for DVD creation
Authoring DVD Folders
00:00:00: Creating TitleSet # 1
00:00:00: SVCD2DVD: DVDfolders
Generating DVD folders please wait....
00:00:00: -->: DVDFolders creating VTS
00:00:00: -->: VTS 01
00:00:00:
DVD Folders: Processing K:\xxxxx\BM_S2D.mpg...
00:06:13:
00:07:21:
00:07:21: Finalising DVD...
00:07:21: SVCD2DVD: DVDfolders
00:07:21: -->: DVDFolders creating table of contents
00:07:21: scanning K:\Temp\SVCD2DVD_OUTPUT\VIDEO_TS/VTS_01_0.IFO
00:07:21: Finalising DVD...Done
00:07:21: Done: Authoring DVD Folders
Results 1 to 1 of 1
Skipping - stuttering
By bryankendall in forum DVD & Blu-ray PlayersReplies: 3Last Post: 17th Jan 2010, 12:55 -
New music skipping
By Jeikobu in forum Portable VideoReplies: 0Last Post: 24th Jan 2009, 14:13 -
More frame skipping in attempted RMVB conversion
By Dorfnarr in forum ffmpegX general discussionReplies: 5Last Post: 5th May 2008, 15:16 -
MEncoder skipping frame with audio conversion
By Towin in forum Video ConversionReplies: 2Last Post: 24th Mar 2008, 12:08 -
HI8 Skipping
By jgeise01 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 1st Aug 2007, 02:58
