I'm trying to combine four separate .wmv files into 1 vid. I am using Nero 6 to complete the burning process. Can I combine these four vids into one vid and then rename the vid using Nero? Or, do I need another program? The size of each individual vid is between 13mb and 34mb. TIA
Results 1 to 9 of 9
Try using the Easy Video Joiner. You can get it here http://doeasier.org/joiner/downloads.html
An eye for an eye can make the whole world go blind! -
Hi there, lordmajax
It's customary to make the subject a tad more descriptive than this.
An example, on the house: How to join WMV?
/Mats -
No, you can edit the subject line. Just edit your first post in this thread. It's not only "customary" - Your thread will attract more interested viewers too!
/Mats -
TrueOriginally Posted by mats.hogberg
. It would be better if you are a little bit specific on the subject. Peole will have an idea what your thread is all about even before reading your post.
Hey, a fellow resident of the land of the nearly dead and the newly wed!
Whether or not Nero will do it I don't know. I DO know it is a bad idea. Nero is a decent burner, but crappy video prog.
Do you want to end up with a DVD-compatible video, or just a single WMV, which will not play in most standalone DVD players? For MPG, you will need to re-encode. -
I definitely want it to be playable on most stand alone dvd players.
convertxtodvd, add all wmvs and convert to dvd-video that will work on dvdplayers.
Good program from cut/join .mpg .wmv files.
By Beautiful Alone in forum EditingReplies: 1Last Post: 27th Jul 2009, 17:57 -
best programs to join wmv from command line
By ziptip in forum Newbie / General discussionsReplies: 2Last Post: 30th Dec 2008, 02:02 -
how do I join 30 .wmv files together before converting to DVD format
By dvdnewbie64 in forum EditingReplies: 3Last Post: 14th Dec 2008, 23:58 -
how can i join VC-1(WMV-3)files
By sumeshkri in forum Video ConversionReplies: 3Last Post: 26th Oct 2008, 01:21 -
Is there a way to join or merge WMV files?
By srauch in forum EditingReplies: 4Last Post: 8th Sep 2007, 17:39
