hello,
I have a winfast tv card that I use to record football shows. I was told to use avi to capture in especially if I am going to do some editing of the clip, but I have found the files are really huge.
My editing consists of either cropping scenes and converting them to shrot wmv files for my website, or cropping out commercials and burning to dvd.
This being the case can I just capture in Mpeg instead?
And if so I have noticed that I can still pick different codecs to use with mpeg? Such as PICVideo, Should I just stick with the mpeg codec?
Also what should I set the following at?
Bitrate?
Video compression mode?
Target Data Rate?
Thanks for the help?
The PICVideo MJPEG codec is a great codec. It is not freeware but it is fairly cheap. If you have it set even to the highest setting (meaning the lowest amount of compression) you will still get files that are around 50% smaller than uncompressed AVI.
Another popular codec that is freeware would be the HuffyUV codec. It can also compress by around 50% vs uncompressed AVI.
Some people feel that HuffyUV is the better of the two image quality wise and that way be so but for reasons that are somewhat hard to put into a (few) words I still prefer PICVideo MJPEG myself. In fact you can use PICVideo MJPEG without buying it to see if you like it ... until you buy it you get a BIG watermark across the bottom of the image.
I already have the PICVideo codec and use it when I am capturing as avi.
However would I be better off capturing as mpeg and use the mpeg codec instead of avi due to the simple editing I do. I just seem to have much better file sizes when I capture as avi and havent noticed a difference in quality compared to avi either?
Also if I should use mpeg what should I set the following at.
Bitrate?
Target Data Rate?
Thanks -
Realtime MPEG encoding while capturing won't give you as good results as capturing to HuffYUV or MJPEG followed by a 2-pass, high motion search precision, encode later. It may be good enough for your purposes though.Originally Posted by trueman
Use whatever bitrate is needed to fit the desired running time on a DVD but stay within the limit of DVD, <9000 kbps or so.Originally Posted by trueman -
https://www.videohelp.com/tools?tool=VideoHelp_Bitrate_calculator
jagabo is right. Use the link above to set the proper bitrate. Assuming your using a single layer recordable dvd set your bitrate accordingly.Originally Posted by truemanDonatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
Capture VHS, what formats to use
By Linuus in forum MacReplies: 6Last Post: 9th Apr 2012, 14:16 -
How to convert MP3, MPEG, AVI to Windows Media Formats (algorithm)
By Nemo_wf in forum Video ConversionReplies: 0Last Post: 13th May 2010, 07:05 -
Quality loss from D V -AVI to other formats
By santolina in forum Video ConversionReplies: 20Last Post: 24th Jul 2009, 15:24 -
Still Images from MPEG formats
By ath1517 in forum Newbie / General discussionsReplies: 3Last Post: 11th Dec 2007, 11:09 -
Capture Software for VHS to MPEG/AVI
By quantass in forum Capturing and VCRReplies: 1Last Post: 7th Sep 2007, 15:22
