I´ve been trying to convert XVid into DivX files in order to play them in my DVD player.
I tryed Nandub, but I could only extract the first audio stream. I tryed to save the XVid file in Nandub in direct stream copy with 'no audio' as primary stream and 'AVI Audio' with 'Direct stream copy' as secondary stream in order to obtain a new .avi file with only one stream and then extract that stream as wave. But the new file is mute, even if the size of the file seems that it contains that audio stream.
Is there a program to demux AVI tracks, like vStrip does with vob files?
I hope somebody could understan my lousy english and answer me.
Thanks.
Guilherme Nielsen.
virtualdubmod might be able to assist. Older versions (around 1.5 ish) allowed you to go to streams > stream list, and then simply select the track you wanted to keep and allowed you to disable the other track.
If in doubt, Google it. -
Most DivX players do XviD as well. Doesn't yours? If not, it may be just a matter of changing the four cc from XVID to DIVX.
If at all avoidable, don't reencode.
/Mats -
mats.hogberg I totaly agree with you, I tried to run my XVid files, but it freezes freezes around the middle of the movie, and it seems my DVD player can´t read the 'total time' of the files nor use the function 'goto' in this files. Thanks for your help.
Bullseye! Thank you, jimmalenko! I tried virtualdubmod from Gordian Knot Rip Pack, which I have in my PC, and it does the trick.
Demux and cut mp4 files?
By kewlar in forum EditingReplies: 0Last Post: 30th Sep 2010, 16:51 -
How to demux .m2ts files in OSX???
By bendermac in forum MacReplies: 11Last Post: 19th Jan 2010, 22:08 -
Demux Matroska files
By Anicsi in forum MacReplies: 4Last Post: 16th Dec 2009, 12:41 -
Karaoke DVD -> Chapters (2 audios) -> .mpeg (2 audios) ???
By webking1 in forum Newbie / General discussionsReplies: 3Last Post: 16th Feb 2009, 11:49 -
how to demux avi files?
By GeeForce11 in forum Newbie / General discussionsReplies: 6Last Post: 25th Feb 2008, 16:09
