Just wondering what the diffrence is if anything will it encode faster opr antyhing anyone know please let me know thanxs!
There are a number of differences. The major ones are the amount of configuration you can get into (more in pro than free), and the re-authoring options available in the pro version. You can do movie only and other variations without having to process through something like DVD Shrink first. You can set individual titles to half-D1 - great for TV series, where the free version can fall down.
Is it worth it ? That's a harder question. When it was $10, the answer was definately YES. Now that it is $30, it's a harder call. I does bundle much of the functionality of DVD Shrink into the re-authoring section, but if you have a comfortable process, you might not get as much out of it.Read my blog here.
Is English your first language? Do you proofread before posting?
No, encoding speed has nothing to do with your version of DVD-RB, but with the encoder used and the CPU power of your computer.
Just about anything DVD-RB Pro can do that the free version can't, can be done fairly easily with freeware tools, with a few exceptions. As mentioned, half D1 resolutions are possible with the Pro version. Reencoding menus to shrink them can be pretty tricky, and compressing DVDs with Angles/ILVU while keeping the angles can be damned near impossible. If you keep the menus as is, or use MenuShrink on them to cut them down to size, then the freeware version is OK. If you strip out all but one angle, then the freeware version is OK. The only time I use it the Pro version is when I have a DVD with angles and I want to keep the angles. -
Thanxs for the response guys...sorry about the misspelling I was really tired and didnt notice
Using DVD Rebuilder PRO Moblie setting.
By budz in forum DVD RippingReplies: 2Last Post: 29th Apr 2010, 15:50 -
Problems with DVD Rebuilder Pro and Procoder 3...
By twangling_jack in forum DVD RippingReplies: 5Last Post: 21st Jun 2009, 19:12 -
Problem DVD Rebuilder Pro: Is not a ECL for CCE SP Trial Version
By Talayero in forum DVD RippingReplies: 2Last Post: 30th May 2008, 14:25 -
Wich freeware encoder is best with DVD Rebuilder?
By julitomg in forum DVD RippingReplies: 12Last Post: 21st Oct 2007, 23:10 -
DVD Rebuilder Pro & CCE in Multipass VBR mode
By devnulllore in forum Newbie / General discussionsReplies: 12Last Post: 30th Jul 2007, 10:04
