hey mozartman i just read this in the dr-m100s manual and the dr-m10s manual :
do you know how to check for 5c copy protection on channels?It is impossible to record onto DVD-R/RW (Video mode) discs
broadcasts that allow you to copy once. The copy once
programs can only be recorded onto DVD-RW discs formatted
in VR mode.
are you sure you wree copying from a 5c copy protected show.
Are there such things i can buy to break this copy protection?
Results 31 to 51 of 51
FYI. Anyone looking for the Toshiba DR-4 check out Best Buy. Just pick up one for $129.00. There was one open box but it was only 10 bucks cheaper.
The D-R4 rocks, best picture quality I've seen hands down. I picked 2 of them up on ebay for about $63 each.
While I like the PQ of the DR-M100S the one thing I find unacceptable is that it is unable to record the closed caption information on recorded programs. Come on JVC, why did you fail to incorporate this 'no-brainer" feature.
just got the JVC dr-m100s dvd recorder and am recording 5c copy protected channels perfectly fine
hmmm just wondering, would different media produce different picture quality? i know different media produces different burn quality, but what about the picture quality with media?? -
No. This is not analog. Media does not affect video/audio quality.
@divuer .... JVC does do CC. It's not advertised anywhere, but if you record a DVD on it, and press mute on a CC-enabled tv, there it is. Of course, this assumes what you recorded had CC, not everything does. You also need DVD-VIDEO mode, not VR mode.Want my help? Ask here! (not via PM!)
closed caption is just the words on the bottom right? why does it have to be in mute?
If i record a show on comcast, does it record caption?
[quote]No. This is not analog. Media does not affect video/audio quality. [quote]
So for instance if i record a show with shitty memorex media and the same show with taiyo yuden, i will i get the same picture quality??????
Hey lordsmurf, does this jvc record the exact same audio the source tv show is using? and if so, does it do it by default or would i have to set it?
EDIT : Lordsmurf, should i know about any settings on this JVC to optimize PQ before i start recording everything? or can i just record right out the box ?? -
Ready out of the box. I suggest you use FR185 recording mode for best quality, gets just over 3 hours on a single disc too.
Have you never used CC before on modern tv sets? Because "why does it have to be in mute?" is a really silly question.Want my help? Ask here! (not via PM!)
In other words ... most modern televisions will automatically show CC (if it exists) when you press the MUTE VOLUME button on the TV.Originally Posted by lordsmurf
If the TV does not do this automatically but does support CC then you should be able to set it up in the menu to do this automatically when you press the MUTE VOLUME button.
Of course who uses the TV speakers anymore LOL
is cc the same as having the volume up and having the words at the bottom?
whats it called when you have the volume up and you cant understand because the actor is mumbling, and you can turn something on to see the words.
and about the different xp or sp settings, that was going to be my next thread. -
I have a JVC MH30 and record widescreen material from time to time and it does it flawlessly. For this to happen it all depends on your cable or sattelite receiver. I set my HD reciever to output 16:9 and full-screen using Svideo cable. I use a 4:3 TV, so the picture looks kinda squished and commercials with a 4:3 AS has the black bars on left & right. There should never be black borders on top or bottom. If you see this, then the recorder will not record as it should. When I burn to DVD-RW and play on computer it is as it should be, in true widescreen format.Originally Posted by MozartMan
Like I said the key here is te signal your receiver outputs. My old Dish Network 6000 HD receiver is unable to send via svideo the proper 16:9 signal to the recorder. It automatically assumes 4:3 output. I have a MIT MDP-200 HD receiver that can also do over the air HD signals and it can be set to output the proper signal through svideo to the recorder. -
Ok now what settings do you set in your JVC recorder to make this anamorphic widescreen? and what setting on your cable box do you change?I set my HD reciever to output 16:9 and full-screen using Svideo cable. I use a 4:3 TV, so the picture looks kinda squished and commercials with a 4:3 AS has the black bars on left & right.
I have a comcast dct6412 motorola HD cable box. It lets me go in the menu and tell the box that i have a 16:9 tv and then there are 2 other setting :My old Dish Network 6000 HD receiver is unable to send via svideo the proper 16:9 signal to the recorder.
1) ypbpr = 480i/480p/720p/1080i/1080p
2) 4:3 override = off, stretch, 480i, 480p
So what settings do i have to use????
There is a thread about this at avsforum : http://www.avsforum.com/avs-vb/showthread.php?t=663367&page=2&pp=30
A guy claims he make anamorphic widescreen with comcats box but then another guy in the same thread said it doesnt work.
HMMMMMMMMM -
I wish it was so but here's the response received from a JVC Escalation Agent:@divuer .... JVC does do CC. It's not advertised anywhere, but if you record a DVD on it, and press mute on a CC-enabled tv, there it is. Of course, this assumes what you recorded had CC, not everything does. You also need DVD-VIDEO mode, not VR mode.
Thank you for your recent e-mail inquiry to JVC. We, at JVC, regret the difficulty you have experienced with our product, as well and any inconvenience those difficulties may have caused you. Unfortunately this model will not record closed captioning on the DVD recorder deck of this unit, we have done test on recording closed caption and have change the settings but the unit will not record the closed caption.
Could this be a firmware issue? Does anyone know how to verify the firmware loaded on their unit? -
XP would be the best quality, right?Ready out of the box. I suggest you use FR185 recording mode for best quality, gets just over 3 hours on a single disc too.
Hey lordsmurf, i just read the manual and it said something about XP mode with dolby digigtal recording
it said this for the LINEAR PCMS indicator :
Lights when "XP MODE REC AUDIO" is set to "LINEAR PCM" (see page 59) for recording with dvd-r,dvd-ram,dvd-rw discs, and when linear PCM audio is displayed.
and then on page 59 it says :
XP MODE REC AUDIO - DOLBY DIGITAL/LINEAR PCM
You can select the audio format when you record a title in XP mode. When this function is set to "LINEAR PCM", you can obtain a high quality audio sound.
DOLBY : to record in dolby digital format
LINEAR PCM : to record in linear pcm format.
Should i set it to linear pcm if im using xp mode when recording shows?
Also, whats a SAP program.
It says this for SAP programs
2ND AUDIO RECORD - OFF/ON
When this function is set to on, if a SAP program is received, the sap audio is recorded on l?R tracks. the main audio is not recorded. -
SAP=second audio program, usually a radio station or Spanish. You use PCM for audio recording, don't use it for video, it uses a lot more disc space than DD and the video won't be as good.
Set it to 16:9 and 480i. 480i, because you will be using svideo or composite cables and your recorder only records interlaced video only.Originally Posted by mikej3131
I have a Motorola DCT6412 III with Comcast cable TV in the Pittsburgh, PA area.
I've tried setting the Motorola to a 16x9 WS TV and 480i for component out.
This does NOT give me 16x9 WS out via the S-video output.
VCR Comparison: JVC SR-W5U vs JVC SR-V101US
By robjv1 in forum RestorationReplies: 18Last Post: 22nd Apr 2021, 04:36 -
Help Converting JVC VHS to Toshiba DVD Recorder
By pwquilts in forum Video ConversionReplies: 3Last Post: 10th Jul 2010, 09:47 -
Which one is better? Samsung D392 (mini-DV), Toshiba P10, Toshiba H20...
By renavspainatal in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 5th Nov 2009, 09:59 -
JVC SR-MV55US - Users with Experience with JVC Professional S-VHS/DVD Decks
By Anonymous4 in forum DVD & Blu-ray RecordersReplies: 6Last Post: 21st Aug 2008, 16:23 -
Should I BUY the Canon HG10, JVC GZ HD7 or JVC GR HD1 ??????
By thecuban in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 6Last Post: 27th Dec 2007, 13:40
