Hi there, so after some trial and error, I've had the following journey:
1) I was able to successfully convert an AVI (DiVX) to DVD (Video/Audio-TS) folder.
2) I then discovered that the DVD functionality of ffmpegx could only make a Video-TS folder out of one file.
3) I want to add multiple files to one DVD, so I discovered one could do that with Sizzle (0.5b2). (by creating multiple titles)
4) Now, for some reason, I've been unable to convert the audio in a DiVX file to AC3, successfully. the result is a file with a ".ac3" extension that looks _far_ too small to actually contain any audio. Sure enough, when I try to import it into Sizzle I get an error message "some audio in this file does not appear to be MP2, AC3".
5) So, I've tried re-converting the AVIs using the MPEG-TS preset, to create a muxed MP2 file, and Sizzle seems to understand some of those files, but not others.
Sorry for the long post, I've been at it a while before I tried asking for any help. I'm also not in front of my Mac, so I may be missing some details.
Any help would be appreciated!
	Actually, that particular problem seems to have resolved itself. Sorry for the delay in responding!
 I do have another issue, but it likely falls out of scope of an ffmpegx forum. I'll ask anyways.
 I've been able to successfully burn a DVD from an image I've created in Sizzle. I mounted the image and tested it in Apple DVD player before I burned it, and everything seemed to be in order. Then I successfully burned the DVD using Disk Utility. The resulting disk also seemed to work fine on my machine.
 However, when I try to play the disc in my standalone unit (Magnavox MRV660), the TOC loads, and appears to work, but each title only plays back for about 5 seconds, then the screen freezes, but the counter on the player keeps going.
 I suspect this might have something to do with interlacing. Am I way off base? Thanks in advance!
  n00b question on format to useBy hbguru in forum Video ConversionReplies: 1Last Post: 28th Jan 2012, 16:08
  n00b question about pc and hd cableBy NateDizzle in forum Capturing and VCRReplies: 10Last Post: 17th Mar 2011, 17:35
  n00b question about pulling out clips from a dvd. HELP!!!!!By CaptainZissou in forum Newbie / General discussionsReplies: 2Last Post: 10th Oct 2009, 02:03
  n00b question (sorry!) re: installationBy pomoster in forum ffmpegX general discussionReplies: 2Last Post: 5th Feb 2008, 19:44
  N00b question: Is re-encoding useless?Need some advice....By DavidHazelnut in forum Newbie / General discussionsReplies: 4Last Post: 9th Nov 2007, 20:43
 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
