I was given an AVI video that, although QuickTime Player could play it, ffmpegX could not convert it to H264 for iPod without messing up the A/V sync. The issue was the AC3 audio that QT said was using an "unidentified" AC3 codec. (But it did play in QT!)
I searched for some way to extract the audio and convert it. Audacity choked. DivX Doctor choked. Then I remembered another method I had used in the past.
I did an intermediate conversion using the DivX preset which has an audio preset of mp3. I set the pixel size and bitrate to match the source file. While the conversion "info" reported some skipped and duplicate frames, the result had good A/V sync.
I then used the H264 for iPod setting with my usual tweaks to maximize quality. Final result is in sync.
Thought this might help someone.
Results 1 to 1 of 1
Converting VFR FLV (H264/AAC) to AVI (other) w/o sync issue
By kwondra34 in forum Video Streaming DownloadingReplies: 43Last Post: 11th Apr 2012, 01:54 -
Audio sync issues - H264 and AC3
By xtrattitude4u in forum Video ConversionReplies: 0Last Post: 6th Sep 2011, 03:22 -
AVIDeMux - H264 (.mp4) to .avi - Audio Sync 1000ms
By nlvraghavendra in forum Video ConversionReplies: 3Last Post: 9th Mar 2010, 15:50 -
Audio Sync issues under Vista 64 and H264/AC3 MKV files at 1080p
By tarrantm in forum Newbie / General discussionsReplies: 3Last Post: 6th Jan 2009, 22:56 -
H264 to AVI out of sync even though same fps was set.
By sooojaded in forum Video ConversionReplies: 4Last Post: 15th May 2008, 03:09
