Hi guys, i am new to all of this and i have the following problem; I got a lot of *.m2v video files and matching *.ac3 files with the audio - i need to multiples the video and Audio and then Author a simple DVD; I have been looking at a lot of encoders and tools but i am not sure which is best to use. Also i need to be able to automate this process, i.e. using command line batch files or something. Anyone any ideas, please assist, thanks
muxman or dvdauthorgui
dvdauthor for a command line tool -
dvdauthor has been compiled to a win32 binary. If you download dvdauthorgui, you can use it a few times to understand how dvdauthor works, then use the binaries for your own automated process.
DVDAuthorGUI creates a temporary batch file, which you can use to understand the process. -
use mkisofs. Again, the binary can be found packaged with DVDAuthorGUI.
The command line should be
mkisofs.exe -dvd-video -V "TitleofDVD" -udf -o C:\test.iso C:\dvdfolder
Extract Audio and video from Multiplex karaoke DVD and re author
By quebecLA in forum Video ConversionReplies: 1Last Post: 8th Jul 2011, 23:01 -
Need something that will multiplex .m2v, .ac3 AND .dat into one .vob?
By Information in forum Newbie / General discussionsReplies: 6Last Post: 20th May 2009, 01:06 -
Multiplex SD Mpeg with ac3 audio
By hartless in forum DVB / IPTVReplies: 8Last Post: 9th Sep 2008, 07:59 -
m2v and ac3 multiple audio tracks to DVD
By gameroftheuk in forum Authoring (DVD)Replies: 7Last Post: 4th Aug 2008, 16:55 -
Demux DVD Video to separate M2V and AC3 files
By ArtOfLosingMFZB in forum Newbie / General discussionsReplies: 3Last Post: 6th Oct 2007, 21:03
