How do i go about installing japanese language pack/support in WinXP home edition? I've already searched google and downloaded some stuff but no luck yet. Links? suggestions please?
Hi Super Warrior;
The Japanese language pack is already a part of XP with no new downloads req'd. Just go to START->CONTROL PANEL->REGIONAL AND LANGUAGE OPTIONS->LANGUAGES and check the two "supplemental language support boxes". You'll be prompted to insert your original system disk. After the files are loaded, you will need to restart your computer. If you don't want to install an "Input Method Editor" (IME) you're done. If you want to type in Japanese though, you have some more work. Next, follow the same sequence above but this time click on "Details" and add Japanese to the supported input languages. If you want to go farther and have service messages given in Japanese, you'll need to click on the Advanced tab instead of the details button and use Japanese as the selected default language. You can also default the keyboard entry to Japanese when you're adding Japanese to the allowable input languages.
Good luck and all the best,
Morse
WinXP SP3 Problems Installing Media Player 11
By bevills1 in forum ComputerReplies: 0Last Post: 31st May 2011, 11:00 -
How Panasonic DMR-E80H convert japanese to english Language
By tanveerriaz in forum DVD & Blu-ray RecordersReplies: 0Last Post: 9th Feb 2010, 07:30 -
Re-Installing OS WinXP Home
By GT Music in forum ComputerReplies: 2Last Post: 17th Jun 2009, 17:47 -
error installing K-lite codec pack
By Shotobits in forum Newbie / General discussionsReplies: 4Last Post: 22nd Mar 2008, 02:38 -
DivX playback problems on Philips DVP 3040 (since installing WinXP SP2)
By mikester2 in forum DVD & Blu-ray PlayersReplies: 7Last Post: 22nd Nov 2007, 12:54
