Just got the following rig.
AMD64 2Ghz (Dual Core) - 2 Gig PC-3200 - 250 Gig SATA - nForce4 - 7600 GT
I was thinking about installing Windows XP Pro 64-Bit Edition, all my drivers are covered, but I was curious about what software out there is written to handle the 64 bit extensions and or handle multiple CPUs.
Even on Win2000 SP4, encoding a HD transport stream is so much faster than my older 32 bit 1.8ghz amd system.
Is it primetime for 64 bit apps? Or should I stick with a 32 bit version of either Win2000 or XP?
there is some high end software for 64bit ... encoding and compositing ,,,
not much in the lower end ...."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
Virtualdub has a 64bit version and there is an Xvid 64bit too. I dual boot, and find even 32 bit apps like Canopus 1.5 run faster in the 64bit environment thanks to efficiencies in memory access. My advice dual boot. run your fav apps in each and time them . .you will be surprised I am sure.
Who is watching the watchers.
meGui and 10-bit encoding
By Enkidu in forum Newbie / General discussionsReplies: 2Last Post: 27th Jul 2013, 20:45 -
LAME 32-bit or 64-bit in EAC under Windows 7 64-bit?
By flashandpan007 in forum AudioReplies: 1Last Post: 12th Apr 2011, 09:40 -
XVD4PSP 5.0-6.0 encoding for HD movies terribly slow on Win 7 64 Bit with..
By pectin232 in forum Video ConversionReplies: 2Last Post: 25th Nov 2010, 20:28 -
64 bit encoding program for MKV to MP4
By prk72 in forum Video ConversionReplies: 10Last Post: 30th Oct 2010, 14:11 -
So What Encoding Software Runs in Native 64-bit?
By Robert Simandl in forum Video ConversionReplies: 2Last Post: 29th Aug 2009, 10:13
