OK guys I have spent some time looking over the forum for info and been studing the how to section .I have to say its quite duanting ,I have a couple of questions, I wish to capture from my video recorder and out put to SVCD format and then to DVD-R in the future (when i can afford a dvd burner). I have spent some time reseraching
the best capture setup I was comfortable with using and also gives excellent qaulity , I opted for the Dazzle DV bridge witch converts analog to digital, I am using DIVO and premeire 6 to capture AVI files , first question are there any guides on using editors which filters to use as I find that the colours in my captures are a bit strong also they could do with brighting up and so on and so on .
I have tried using premire 6 but it takes too long to render or I am using it wrong .
Second question when converting to mgeg2 format using TMPGEnc 2.01 using there svcd template quality is crap so need some advice on resloutions and deinterlacing
Sytem P4 2GHZ
Intel MOBO
512 DDR RAM
OP/S WIN XP HOME EDITION
CAPTURE CARD DAZZLE DV BRIDGE
MAXTOR 20GB 72000 RPM
IBM 60GB 72000 RPM
Results 1 to 1 of 1
Newbie needs help/advice on backing up
By squale247 in forum Newbie / General discussionsReplies: 7Last Post: 11th Feb 2012, 19:27 -
Conversion advice for a newbie
By darafat in forum Video ConversionReplies: 1Last Post: 20th May 2010, 02:17 -
Newbie looking for advice.
By mopar339 in forum DVD RippingReplies: 1Last Post: 14th Feb 2008, 02:36 -
By mopar339 in forum Newbie / General discussionsReplies: 1Last Post: 14th Feb 2008, 02:35 -
Newbie seeking some advice, please. :)
By Gun in forum Authoring (DVD)Replies: 18Last Post: 3rd Jul 2007, 20:07
