hi, i am going to try and use dvd re-builder for the first time, what is the most up-todate and is there any guides on how to use it,
id appreciate an help and TIPS any oone can give me cos i tend to do everything wring at first and then find out a better way like 3 months later
i.e never used this before and backed up loads of dvd-s and now it looks like there gona be rubbish on the big screen compared to dvd-rebuilder, backed up alot of tv programs with 4 eps per disk
thanks
Results 1 to 12 of 12
p.s what do i need, extreme series or encoder series, im so lost
i did search but everything starts with an acceptance htat people know what htere ding, its more about questions about the program rather than a start up guide
Go to the DVD REBUILDER FORUM for help at Doom 9.
http://forum.doom9.org/forumdisplay.php?f=75 -
ok, can i ask, if i had backed up a load of dvd's with a normal program, im i going to ebe compled to rebacking them up with dvd builder
I wish you'd proofread before posting. Your writing and spelling are atrocious and your last post made no sense at all.
My best piece of advice is to make sure you get the installer, or just getting DVD-RB to run will probably be beyond your capabilities.
http://dvd-rb.dvd2go.org/
Go to the Downloads section, and then the free version, and you'll see the Installer package. If you like the free version, the Pro version is better, with lots of added features, and is worth the price.
And, as mentioned, the Rebuilder Forum at Doom9 is worth the visit. There are stickies at the top with lots of tips. -
ok, sorry about my spelling and grqammer,
in my last post i was asking if dvd-rb's results woulod compel me to throw away my old back-upsand start again with dvd-rb, i guess its in the eye of the beholder though
isnt the free version just a test to copy like 3mins of a dvd and not the whole thing, also is the free version gona give me the same quality of results than the pro version or is it just added features, its just im going to a shop in a few h0urs to test dvd-s and i want to know where im up to
anyway ill read the forums u suggested and see if i can cope
thanks again for the help
p.s im not crap with this stuff but when i start something from scratc i tend to get it wrong but when i start thats when i do the most work, i dont want to back up 20 dvds with-bd one w2ay and find there's a better, way, ive already backed up a few hundred dvd-s and now i find there is a better way -
Yes everyone's eyes are different. I can view a backed copy of a movie I did with DVDRB PRO but someone else cannot see the difference if I was to show a backed up copy I did with DVDSHRINK. The results are stunning when using DVDRB whether or not you use the free version or the pro. With the pro you get free updates for life.Originally Posted by slimpickins
I do my comparisons of DVDRB PRO and DVD SHRINK on a 11 year old 32 inch SONY XBR CRT television. With DVD SHRINK pixelation is more apparent than DVDRB. I have a coworker who doesn't care what the video quality is he just uses a program that will require the least amount of mouse clicks to back up his dvd movies.
hi
right, im installing it now,
i have several versions of cce stuff i can install which one
2 boxes
cinema craft encoder
canopus procoder
then there is a section for cce it says version selection
cce basic retail version
cce sp 2.50 - ecicce
cce-trial 2.66/2.67 version - ecicce
cce 2.7 trial versiion - no ecicce
cce sp 2.66/2.67 trial version - no ecicce
then underneayth it has a section for canoput
canopus 2.0
canopus pro
im guessing its cce and one of the top 2 but not swure
thanks again, -
Kind of depends on the version of CCE you're using. If you have the Basic $60 version, then choose "cce basic retail version". Otherwise, choose the version you have. For example, if you have CCE 2.70.02.04, then you choose "cce 2.7 trial versiion - no ecicce"
Canopus Procoder is a completely different encoder. Unless you plan on using it and not CCE, don't choose it.
The free version of DVD-RB does everything. It'll do a complete DVD for you. Yes, same quality and everything.
Should audio track be smaller after DVD Rebuilder/CCE?
By hiimbored in forum DVD RippingReplies: 3Last Post: 22nd Jan 2009, 10:10 -
Problem DVD Rebuilder Pro: Is not a ECL for CCE SP Trial Version
By Talayero in forum DVD RippingReplies: 2Last Post: 30th May 2008, 14:25 -
question about CCE Customized Settings in DVD Rebuilder
By jimdagys in forum DVD RippingReplies: 1Last Post: 30th Oct 2007, 05:20 -
DVD Rebuilder Pro & CCE in Multipass VBR mode
By devnulllore in forum Newbie / General discussionsReplies: 12Last Post: 30th Jul 2007, 10:04 -
Best Advanced CCE Settings in DVD Rebuilder
By devnulllore in forum Newbie / General discussionsReplies: 1Last Post: 16th Jul 2007, 12:56
