What are all these format types. I'm confused?
DV, SD, DV 24p/24pa, DVCPRO 25/50 XDCAM SD, HD, HDV, P2.
I'm looking into premier pro and these are the format it accepts. BTW is it possible to edit mpeg 2 streams on Premier pro, or does a plug-in need to be added. Thanks! -garman
Results 1 to 13 of 13
https://www.videohelp.com/glossary
DV - Digital Video
SD - Standard Video (???)
24p - 24 frames progressive (film format movies use)
HD - High Definition.
HDV - High Definition (high def dv for camcorder)
As for the other question I don't have premier so I don't know.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
Thanks for your imput Yoda. Still can't find any reference to SD, besides secure digital. What do you think about Flash 8 for web video hosting. Will this be good for non animated video. I have only seen Flash products as small cartoon flicks, not captured video. Thanks again. -garman
Thanks jagabo. I found SD format on the Adobe website. Sort of on a shopping spree for work. 7 prosumers camcorders (panasonic adhvx200) and 8 consumer style camcorders (pany VDR-300) These are for field reporters. What do you think of these and what about software. Looking at premier pro for the studio and flash 8 for web hosting video clips. Thanks
What are you trying to accomplish?
You need training wheels before Premiere Pro.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
DVCPRO 25/50 is a high-end professional digital video format. The 25/50 is the bitrate - 25mbps is standard 50mbps is the high quality mode (which uses the tape 2x faster). It looks great but is way too expensive for consumer use.
Our company bought a small tv station. They are trying to merge synergies of the paper industry, the web and now broadcast television. You know send reporters to the field, have them file 2 forms of media video and digital photos and also the written conents. Now editors will decided what gets editited for tv, while the print media uses the story and photos. The web side streams the finished project over the net. That's it in a nutsell. The company is trying to get this off ground soon. Spending $$$ on hardware, software, whatever to get this puppy launched. I've been given a small task of looking into software for editing (video), streaming over the web. Using flash (SWF). Anyway that's about it I could provide more, but I have more research to look at. -cheers
I suggest you hire sombody experienced in editing for TV. Is this a cable or broadcast station? Is the military, FCC or cuban gov't authorizing this broadcast? Different rules apply.
What format camcorders are you using? -
Originally Posted by edDV
Originally Posted by garman
If you haven't bought the cameras yet, you might want to consider HDV format to get started. Much less hassle. -
You need someone with broadcasting experience. It will save you lots of money.
If budgets are tight, forget HDTV altogether and get SD working. Start with DV.
Video Converters that supports most video formats, RM, FLV, WMV, MOV, MP4
By Baldrick in forum Video ConversionReplies: 134Last Post: 31st Mar 2021, 10:27 -
Video Formats
By andyf in forum Newbie / General discussionsReplies: 3Last Post: 13th Oct 2011, 04:10 -
What do these video formats mean?
By Videogamer555 in forum Video ConversionReplies: 1Last Post: 4th Jul 2011, 08:40 -
multicamera video montage with different source fps and video formats...
By foler in forum EditingReplies: 2Last Post: 16th Feb 2009, 04:19 -
* * * Different Video Formats * * *
By wookie1820 in forum Video ConversionReplies: 3Last Post: 20th Mar 2008, 11:23
