I have a DVD with has been mistakenly authored as a 4:3 disc but the video on it is clearly anamorphic (everybody and everything in the picture is squished). I don't really want to have to re-author the whole disc, so I'm guessing that the best way to fix the problem is to rip it to my hard drive, tweak an .ifo file to change the flag from 4:3 to 16:9, and reburn it so that my DVD player will know to letterbox it for my 4:3 TV. I can handle the ripping and re-burning OK, it's just the tweaking of the .ifo file that I'm a bit fuzzy on. Any advice?
Chaoji
you can change the settings in the ifos with ifoedit. make sure to do all of them. open the ifo with ifoedit, double click on the description lines in the bottom pane and change the attributes to what you think they should be. make sure to click save before closing ifoedit.
Need Help with Panasonic DVD-LS83 or DVD-LS86 8" Portable DVD Player!
By Big C in forum Portable VideoReplies: 3Last Post: 1st Aug 2011, 18:35 -
Samsung DVD-HR753 DVD and HDD recorder rejected all my blank DVD
By undangltn in forum DVD & Blu-ray RecordersReplies: 1Last Post: 14th Mar 2010, 13:34 -
CloneDvd2, Dvd Decrypter, Dvd Fab, Dvd Shrink? Help Choosing Software...
By frieday in forum DVD RippingReplies: 10Last Post: 5th Aug 2009, 09:14 -
DVD recorder LG DR175B won't read burned DVD but common DVD Player reads it
By Mycow in forum Newbie / General discussionsReplies: 0Last Post: 12th Aug 2007, 18:59 -
DVD+/-RDL Playback on Yamaha DVD-C750, DV-C6770, and DVD-C950
By Big C in forum DVD & Blu-ray PlayersReplies: 5Last Post: 11th Aug 2007, 09:59
