I try to edit my subtitle with MaestroSBT but i have problem with wrong color subtitle from MaestroSBT.
1.picture of original subtitle (bmp from vobsub)
2.picture from Maestro (primary=red, anti alias=white ,outline=black, background=blue)
3.picture from Maestro(primary=red ,secondary=white ,outline=black ,backgroun=blue)
4.picture from Maestro(primary=red, secondary=white ,tritery=black ,backgroun=blue)
all picture 2-4 not match to pic1![]()
why not?
MaestroSBT doesn't generate as large an alias as you desire. You're going to have to settle on a text color and an outline.
ICBM target coordinates:
26° 14' 10.16"N -- 80° 16' 0.91"W -
Hi SLK001
Right, in the pic2 and i try to set color of text and outline (pic3&4) but they are still not matchMaestroSBT doesn't generate as large an alias as you desire. You're going to have to settle on a text color and an outline.
orinal subtitle(pic1)
They're not supposed to match. You fix it afterwards, when the DVD is complete. You can easily change the colors, even import the CLUT (Color LookUp Table) from the original, using PGCEdit. As stated, the alias probably won't ever be the same again. Looks to me like your outline is too thick and maybe the font too small.
Subtitle Creator error: Input string not in correct format
By kpic in forum SubtitleReplies: 6Last Post: 31st May 2013, 04:17 -
Vegas - Did I color correct this correctly?
By sdsumike619 in forum EditingReplies: 17Last Post: 17th Dec 2009, 21:48 -
Color correct this .mov
By sdsumike619 in forum EditingReplies: 0Last Post: 7th Jun 2009, 18:39 -
Subtitle Input string not correct format/Input subtitle file error (SOLVED)
By Webgirl in forum SubtitleReplies: 8Last Post: 13th Mar 2008, 09:59 -
MaestroSBT Constant Anti-Alias Ratio (Perfect Subtitle)
By Anime in forum SubtitleReplies: 0Last Post: 25th Nov 2007, 03:33
